Halogen beam pattern pics?
Discussion in 'Gen 2 Prius Main Forum' started by bagwell, Nov 19, 2009.
  1. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    just bought a used 08 and the pattern seems a but funny....anyone with pics handy?
    thanks (and yes I searched...found only HID)
  2. bagwell
    592
    49
    the woodlands, tx
    Re: Halogen LO-beam pattern pics?
    here's mine....is this normal?
  3. macmaster05
    macmaster05 Senor Member
    4,050
    729
    The right beam should be higher. HID headlights have a lower angle but a sharper cut off. Halogen beams shine higher but are less bright and fade more the higher you get.
    I have 2 Gen II Prii. One with HID and one with halogen.
  4. chuckknight
    chuckknight New Member
    194
    33
    How does one tell the difference between HID and halogen? I know the color is different, but without something for comparson, that's not very helpful.
    My Prius is also a 2008, and I bought it secondhand, so I'm not 100% sure which I have.
    Is there a marking, a label, or a certain aspect for which to "look?"
    Chuck
  5. macmaster05
    4,050
    729
    Do you have fog lights? If you do you have HID. If you don't you don't have HID.
  6. chuckknight
    194
    33
    I don't have fog lights...therefore, I must have halogen.
    Surprising. My light is nowhere near as yellow as the photos posted above.
    THANKS!
    Chuck
  7. macmaster05
    4,050
    729
    No problem. I agree, the camera makes those halogen lamps look more yellow than they actually are. Also, I know it can be hard to distinguish the color of HID from halogen, if you're only used to one or the other. For example, my mother thinks the Prius halogens are too bright, lol.
  8. bagwell
    592
    49
    the woodlands, tx
    my lights are shining on a almond colored garage door and I took the pic in the early evening;
    your previous owner may have swapped the bulbs to a silverstar ultra or something similar.
  9. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Do they cut out on you now and again? That appears to be a distinguishing characteristic. ;)
  10. chuckknight
    194
    33
    Never, I'm very happy to say.
    Chuck
  11. bagwell
    592
    49
    the woodlands, tx
    HID will be sort of blue when you you turn them on then change to a warm white.
    halogen will instantly turn on to full brightness and not change color.
