Hammer, punch, and oil change success
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bwilson4web, Mar 10, 2013.
  1. bwilson4web
    15,561
    So I was planning the trifecta:
    1. change engine oil
    2. change transaxle oil and get a sample
    3. change airfilter
    I had all the tools, supplies and parts and headed over to the auto-shop on base. I show up and 'sorry, our lifts are down, can you come back next week?' . . . I should have.
    No problem, I'll just raise the car onto jack stands and 'get dirty.' At least I won't be at risk of a rain shower predicted that afternoon (showers never showed up!).
    So I raise the car and gingerly remove the fasteners, several are gone and one obviously broken. Still no problem so I fetch the oil capture pan. But I didn't realize as I walked the length of the bay holding it by one hand that it was leaving a trail. . . . Ok, dry-sweep it up.
    The drain plug was very, very firm. So rolling off the creeper to get a good angle, UGH, it is loose. I began to suspect the Toyota Service Center let the 'gorilla' mechanic do the last one. No problem, capturing the oil. Now to replace the oil filter.
    None of the shop wrench worked . . . none! All I was doing was reshaping the cap. But the guy in the next bay was replacing his lower ball joints using hammers, power tools, and Marine vocabulary. So I picked up the ball-peen and a punch and with persistence and taps, after two revolutions, I could remove it. Replacing the filter was easy enough and with the new "O" ring, back together again.
    Ok, I then started to work on the transaxle oil but was looking on the wrong side. I could not open the Allen plugs and that was a good thing. I'll go back when the lifts are working and bring my tools. But gosh I was disappointed. I still have to replace the air filter but this can be done anytime.
    So my 'lesson learned' is have a hammer and punch. That will free the grip of the oil filter cap.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Didn't someone say "If a hammer can't fix it - get a bigger hammer"?
  3. bwilson4web
    15,561
    A man had a diesel Jetta that wouldn't run and after exhausting all options, visited the local shade-tree mechanic. He looked it over and said,"I'll fix it for $101."
    Not having many options, he said,"Ok but I only pay if it works."
    The mechanic fetched a heavy tool box, opened the hood, and took out a huge sledge hammer. Before the man could say 'boo' . . . BLAM the hammer came down and the mechanic said,"Start the car."
    Sure enough, the engine started right up and the man got out to pay the bill but asked,"Why the $101?"
    The mechanic said,"Well the $1 is for the hammer blow and the $100 is for knowin' what to hit."
  4. Paul79UF
    Paul79UF Junior Member
    27
    Orange County, CA
    The AST tools TOY 640 oil filter wrench is totally worth the $20 or so at Amazon.
    Makes it so easy to get off the filter cap on our Corolla and Prius.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,322
    CA
  6. bwilson4web
    15,561
  7. The Critic
    3,193
    2,322
    CA
    The better tool is always worth the extra money.
    dbcassidy likes this.
  8. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Hey Bob, I actually used a magnetic carpenters level on top of my Prius to make sure it was level when jacked up. I made a mess, but all the WS fluid went in and in the right amount. Nothing like trying to complete the "Trifecta" before thunderstorms are due to show up. Fun stuff.
  9. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    What part of the round roof did you put the level on!?
  10. Mendel Leisk
    38,874
    Besides a 64 mm socket I have on hand an over sized vise-grip, purpose built for clamping on various diameters of oil filters. I've never had to use it for that purpose, mainly use it on stubborn pickle jars, LOL. Also have a tradional band clamp style wrench. With the latter if you get it a bit wet and sprinkle pumice grit on the inside it will really grab.
  11. The Critic
    3,193
    2,322
    CA
    My concern for Bob is that after hitting the cap, he may have compromised its structure. It is known that plastic caps will sometimes shatter if the wrong tools are used for removal.
  12. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    the oil filter cap housing is aluminum, I suggest you get the proper tool to remove it :)
  13. Mendel Leisk
    38,874
    Talk to your service department? Seems they've never heard of torque wrenches.
  14. bwilson4web
    15,561
    I am not too worried about the cap. Worse comes to worse, I'll order a replacement from the Toyota parts counter.
  15. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Its a small plastic 12 inch magnetic level and the roof wasn't that round. Lol.
  16. Mendel Leisk
    38,874
    ^ Put the level on the seam at u/s, at bottom of door sills, commonly referred to as "rocker panel".
  17. bwilson4web
    15,561
    That will handle front/back. What about lateral or is it not as important?
    I went by the auto shop and the lifts are still 'down' pending inspection. So my alternative is to four-point lift . . . not something I'm looking forward to.
    Thanks,
  18. Mendel Leisk
    38,874
    ^ I never thought of lateral being an issue. I use the front jack point with a floor jack, put in two safety stands, then 'round the back and repeat. As long as you have left and right safety stands on the same notches, and your slab is more-or-less level.
    While for the rear support points I follow the Owners Manual, the front support points do seem flimsy to me, like a knife edge. I put the front stands inboard more, at the front end of the longitudinal rib. It's about a foot inward from the rocker panel lip. Here's a pic, the red circled zones:
