Hanging piece of plastic under car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rocketman7, Sep 14, 2019.
  1. rocketman7
    rocketman7 Junior Member
    73
    Central Coast California
    Saw this under my 2004 today. Anyone know what it is? Looks to be a broken plastic part of some sort.
  2. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Wao! How did that get stuck in there?
    What you can see there is the exhaust aluminum sheet, stucked in there.
    From looking at it, it appeared it had already coroded, and fallen off.
    The corroded section is where the 10mm or so bolt is tightened on the exhaust manifold.
    51,154
    looks like you ran someone over :cool:
    Raytheeagle likes this.
  4. rocketman7
    73
    Thanks - but it definitely is a plastic piece that is broken/mangled. I tried to look it up but didn't get anywhere online.
  5. Mendel Leisk
    40,584
    Always good to provide some orientation for the pics. The first one for example, is that taken from driver's side, about half way along, looking kinda diagonally back toward passenger side rear wheel? You can just see a bit of the muffler?
    It's maybe item #19 here:
    Splash Shields for 2004 Toyota Prius | McGeorge Toyota Parts
    #5 Mendel Leisk, Sep 15, 2019
  6. rocketman7
    73
    Good point - it's on the driver's side; if you were sitting in the back seat it would be about directly under your feet. That's a good web site but hard to tell if that is indeed the correct part.
  7. Mendel Leisk
    40,584
    Yeah, not sure. See there's corresponding #20, on driver's side.
  8. rocketman7
    73
    I think we're getting closer - #20 looks to be what is underneath the broken part. A white ABS type of plastic. I'll try to get a better look today. Duct tape for the moment...
  9. rocketman7
    73
    Here’s a view from the rear looking forward.
    donbright and Mendel Leisk like this.
  10. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    How big is that plastic piece? Can't you removed it out, and take a full picture?
  11. rocketman7
    73
    Fairly large - there are a few bolts still holding it in. Looks to be a bear to try to R&R...
    Also, underneath it looks to be an orange cable - I'm guessing an electrical line.
  12. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    I've never owned Gen2, but I have not seen any white ABS type plastic used in Gen3 or PRIME so far. Do you think it is OEM parts?
  13. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Take it to a shop to get that sorted out, since you can't removed it. That saves you a lot of time
    rocketman7 likes this.
  14. rocketman7
    73
    Yea, I'm the original owner since 2004.
    Salamander_King likes this.
  15. bisco
    51,154
    orange is the high voltage from the battery
  16. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    I'm guessing it is protecting the high voltage cable from road damage.
  17. bisco
    51,154
    not anymore
  18. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    It the HV cable tray that takes the HV from the battery to the inverter. It is a decent repair at the dealer, but I think you want that repaired properly.
  19. rocketman7
    73
    Thanks,
    Sam
