Hankook vs Firestone
Discussion in 'Prime Accessories and Modifications' started by Mikhail Bond, Dec 30, 2020.
  1. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Can anyone help me pick between these two.
    The specs seem similar but I noticed that the hankook can hold 3k lbs
  2. Mendel Leisk
    41,889
    West coast of USA?
  3. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Yes west coast, but I frequently drive north.
    Weather is getting pretty bad but I don't think I can justify a winter tire just because of the wear factor.
    TGrracie likes this.
  4. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    The Firestone talks about being a 65000 mile tire, the load limit is almost half of the Hancook. Do you need 3k lbs? that's 12k totaI, the Prius isn't rated for 6 tons well above the Prius load limit
    My take: the Firestone is presenting a high life time mileage replacement tire, the Hancook looks to be a more agressive tire, although I'm not sure the stiffness they discuss on their web site is a plus in winter driving. . It's also a bit less expensive, If you were looking for a compromise all around tire to deal with occasional snow, the Hancook is the choice, in my opinion, I would be interested in what you bought (1 1/2 months later :) )
    If I were looking for the best all season tire, to deal with snow, I would check out Consumer Reports reviews of same.
    #4 Glenn G, Feb 18, 2021
    Hicksite likes this.
  5. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    I think the hankook weight rating is a description error.
    I went with hankook and the actual tires state 1650.
  6. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    If you need some snow traction, yes I would go with the Hancook also.
  7. MTN
    MTN Active Member
    306
    276
    SB, CA
  8. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    No I went with 205/75/15
    This gives you roughly a 1" lift
    No rubbing or scraping
    4 Hancooks cost me 280 with tax and my last val tire shop does a mount and balance for 40 dollars.
    320, all said and done.
    MTN likes this.
  9. Mendel Leisk
    41,889
    Did you do the math on odo/speedo error?
  10. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    That being said.
    I will be switching to firestone 215/70/15
    The Hankook tires info was wrong, they actually weigh in at 22 lbs and that is a pretty big deal for mpg
  11. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    I was just thinking about this last night,
    It's about 8 percent
    Gps speed 50, odo shows 3mph difference.
    I removed my cargo carrier and my read mpg shows 40 mpg vs the 35 I was getting all week.
    I'll have to run a full tank to dry to get more accurate results.
  12. Mendel Leisk
    41,889
    I was thinking even more, since speedo typically reads high (with stock tires), it’s supposed to. But with this tire calculator:
    Tire Size Calculator
    I get 752 revs-per-mile with your oversized tires, and 808 with the stock 195/65R15.
    808/752=1.074
    So yeah, 7%.
  13. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Interesting note:
    Charged my car at work, it showed 20.9 miles(full)
    distance to home...22 miles
    I arrived home with 1.4 miles to spare.
    This has never happened.
  14. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Just received a new firestone A/S, hard to get good information these days.
    Firestone tire weighs in at 21 lbs
    Hankooks weigh in at 19.6lbs
    Firestone tread looks to be a little more aggressive and the sidewall is more in line with the width, the hankooks sort of balloon out, maybe due to the rim width being thinner.
  15. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Ok so here are my stats for the hankook
    No cargo carrier
    43mpg
  16. Prim.e.xample
    Prim.e.xample Active Member
    164
    107
    Indiana
    2020 Prius Prime
    Anecdotally I have only had Hankooks once on my old Camry, and absolutely hated them. I usually buy all-season tires and don't do off-roading or anything extreme, so my tires are usually invisible. With the Hankooks I could tell I was losing traction more frequently. Was glad to get rid of them FWIW.
  17. MTN
    MTN Active Member
    306
    276
    SB, CA
    My VW came with Ecopia like many Primes do - replaced them with Hankook Kinergy PT H737 - great tire with 90k warranty. Lots of value for the price.
  18. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    update.
    Keep in mind my car was fully loaded
    2 humans
    2 dogs and a cargo carrier plus surfboard and a 12v fridge
    36mpg on a 500 miles trip
    Hankook optimo H724 205/75/15
    500 treadwear
    Firestones were ok but my mpg dropped to 30, I believe due to the increased width
    215/70/15
    Newest tire
    Hankook kinergy 205/75/15
    680 treadwear
    I'll update my stats as I drive around.
  19. Mendel Leisk
    41,889
    Are you going by what the car tells you? That might actually be accurate, lol:
    In my experience (with stock tires) the displayed mpg is about 7.5% optimistic. By “design” I think: Toyota’s execs saw a cheap bragging rights ploy and couldn’t resist.
    Then, your oversized tires will have the car thinking you’ve travelled roughly 7.5% less distance (per our earlier discussion and calf’s).
    So it balances out. :)
  20. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    I actually went by filling up and then refilling with odometer mileage divided. I noticed that my cars mpg readout was more accurate the more miles traveled.
    If you only go 50 miles then it's about 2-3 mpg off
    I think this is because cost savings comes from the hybrid motor kicking in a low speeds
