hard ride
Discussion in 'Gen 3 Prius Main Forum' started by sanluca2, Oct 5, 2016.
  1. sanluca2
    sanluca2 New Member
    uk
    hi . just bought 2012 prius face lift.. experincing quite hard ride over man holes and drains bumps? is this normal???
  2. prev93
    prev93 Member
    63
    Califon, NJ
    If you keep your tire pressures in the recommended range, the ride should be normal for a car that size.
    52,390
    no it's not normal. how many miles on her? oem or what tyres? any possibility of suspension work by prior owner? and yes, tyres pressure is very important as pref93 states above.
  4. winner_downtheline
    winner_downtheline Junior Member
    Tampa Bay, FL
    @bisco tires pressure for 2012 Prius Four should be at 40PSI for all the tires or 35PSI?
  5. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    What tires and tire pressures are you using? Does your car have any suspension mods? It wouldn't surprise me if the previous owner had the tires inflated to maximum sidewall pressure for better fuel economy (at the expense of a harsher ride).
  6. Mendel Leisk
    41,903
    What is "face lift"? In particular, what tires (tyres) are on the car, and what pressure have you set them?
  7. ETC(SS)
    7,355
    Check your tire pressures (you probably call them tyres) and tell us what kind of car that you drove before getting the 2012.
    If you WERE driving something like a Rolls-Royce Phantom before getting the Toyota, then yes......the ride might seem a bit more harsh.
  8. Mendel Leisk
    41,903
    What the hell: auto correct is changing our "tyres" to "tires".
    Did it again, lol.
    This is what my post #6 looks like when I reopen in the editor:
  9. ETC(SS)
    7,355
    &^^$#@ Website.
    I just checked......I typed "t-y-r-e-s" and it still appears as "t-y-r-e-s" without the quotes and dashes in the edit screen, but PC transmorgified it into "tires" on the interweb.
    (*sigh!*).....
    It's time for a cup of COFFEE!!!!
    (now.....let's see if they change it from tea to coffee!)
  10. Mendel Leisk
    41,903
    You mean "I typed tYres". Les' see how that comes out.
    What I typed, and what still shows in the edit window:
    Try tyyyyyyres. Yeah, now we're talking.
  11. Mendel Leisk
    41,903
    Bisco always types, well, you know what, and he used to get away with it. He'll be hurting now, lol.
  12. bisco
    52,390
    ya, it took me awhile to get used to it.:mad:
  13. bisco
    52,390
    factory spec is 35f/33r, but i run 42/40.
    winner_downtheline likes this.
  14. bisco
    52,390
    tyres
    edit: i typed the above with a y, but it changed to i. funny thing, when i edit, it still shows y.
  15. ETC(SS)
    7,355
    Yeah.
    I know.
    Another "feature" of the site upgrades, along with the free extra posts.....extra posts.....
  16. BZzap!
    BZzap! Senior Member
    1,607
    878
    Just spell "tars" like they do in Texas.
    bisco and lar.smith42 like this.
  17. Mendel Leisk
    41,903
    I think the double posts, and hang ups, are gone! I hope so anyway.
  18. winner_downtheline
    Tampa Bay, FL
    Thanks @bisco - What do you recommend for warm climate like Tampa, FL?
  19. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Here in Double Oak Texas (warm climate) I run 38 psi in front and rear "Tars". Get softer ride and don't make any difference in fuel milage.
  20. bisco
    52,390
    it's personal. i have never found higher pressure to make much of an mpg difference. i do it to get whatever 'edge' i can. but there is a tradeoff with harshness. so you have to experiment. i don't think climate makes a difference, we range from zero to 105 degrees, high and low humidity, and i keep my 'tars' the same year round.:cool:
