Hardwiring A dash cam without fusebox?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Slavatheshrimp, Mar 1, 2020.
  1. Slavatheshrimp
    116
    73
    Mather
    Hey fam.
    Anyone succeed with a hardwire dash cam installation without having to hardwire into the fuse box? Can I not split a wire and just run the positive and negative wire that way?
    Thank you.
  2. ASRDogman
    ASRDogman Senior Member
    6,088
    3,273
    I just tapped into an empty fuse. Used the "hot" side. It only comes on when in the ready mode.
    If you tape into a wire that's hot all the time, the camera will be on all the time.
