Harm in "ready" mode?
Discussion in 'Gen 2 Prius Main Forum' started by archie70, Sep 15, 2010.
  1. archie70
    archie70 New Member
    22
    Miami
    Aside from using gas of course is there any harm in idling (ready mode) for extended periods? What do you think the upper limits (time) might be with the AC on low? Sometimes i find a need to leave the car in ready mode and want to know if Im causing any premature wear and tear.
  2. Patrick Wong
    18,200
    6,472
    There is no upper limit other than that dictated by the fuel tank capacity (i.e., running out of gasoline.)
  3. Jolly English Gentleman
    Jolly English Gentleman Junior Member
    47
    Spalding, Lincolnshire, Uk
    Could be days or even weeks then:D
  4. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Well you will be putting more wear and tear on alot of parts. But who knows if it will shorten the life of the car. But you may have to replace some parts sooner like the ac compressor, Fuel pump things like that. But i wouldn't worry at least your not burnning gas the whole time your car is just sitting there.
  5. richard schumacher
    7,663
    1,038
    United States
    There's nothing "premature" about it. Cars are meant to be used. Far worse to be sitting in ACC or IG-ON, because they will kill one or other of the batteries.
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I suspect the most likely "harm" from repeatedly and frequently having
    the car in "Ready" for extended periods would be early failure of the
    DC-to-DC converter coolant pump. As Patrick, Hobbit, and others have
    noted, it runs whenever the car is in "Ready."
    While the pump's probable service life is typically expressed in "miles
    driven" -- usually given as 100k miles, but failures have been reported at
    ~65k miles -- it's life would be more properly expressed in "hours in
    'Ready.' "
    So let's see, 100k miles at say 30 MPH overall average -- gotta' count
    time stopped at lights, etc. -- would be equal about 3333.33 hours.
    How many hours do you think you will spend sitting stopped with the
    car in "Ready?" :rolleyes:
  7. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    What do you mean by extended periods? Hours or 15min?
    2 of my kids are in dance and between 2 2007 I leave my teen in the car doing homework with the AC on low for 45min twice a week (so calif area hot). Not had any problems. It works very nicely not running the gas engine constantly. As with cars, something could break tomorrow or never.
    Before that constant bumper to bumper traffic (just about idling going no where), no problems there either.
    Do regular maintenance and the mechanical things will last longer. Of course idling saves on tire wear, brakes, lights, excess engine wear at high speeds, switches, washer fluid and all kinds of other things while not moving.
  8. archie70
    archie70 New Member
    22
    Miami
    Thanks for the replies. I drive around quite a bit with my two dogs. In the past Ive leashed them everywhere I went for I didn't want to leave them in the car in hot florida weather for any length of time. However, in the Prius I find myself leaving them more often in the car with the AC on low and the doors locked. I haven't left them longer than 15 minutes at any one time but I just may after these responses leave them for longer periods. Also, I may just sleep more often in the car instead of sleeping out in the tent when camping.
  9. Dodey23
    Dodey23 New Member
    Los Angeles
    Idling is usually a concern in big engine cars from what I recall. Having the engine running with and AC on and not having any air movement on the engine would harm them. I dont think it is even remotely an issue with a prius. In fact many people have camped in their priuses and kept them on overnight for a nice 70degree slumber party :)
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Now you're worrying me! :eek:
  11. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Dont warry, replace your 2010 HEV with a new PHV when it is available, you will get 5000 pounds grant from your government I heard!
