Harmonic Balancer Tool
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LazarusSyndrome, Apr 17, 2024.
  1. LazarusSyndrome
    LazarusSyndrome Junior Member
    17
    Indiana
    Hi I'm looking for a tool to hold the harmonic balancer in place while I torque it to spec I found this on Amazon but I'm not sure if it will fit a 2012 Prius
    https://a.co/d/6lhpBkU
    There is also this three pronged claw thing Ive seen a bunch come up in searches but I think it's just for pulling it off once the crank bolt has been removed.
  2. Tombukt2
    Tombukt2 Senior Member
    8,876
    1,549
    Durham NC
    You don't have any belts on this car so you just wrap a strap wrench around the pulley and hold the strap wrench in the direction you want to hold it I never heard of doing anything so crazy but that should work usually I just blast the bolt on and/or off seriously with the crankshaft pulley bolt I don't think you're going to really super over torque it unless you're just that kind of person I guess as that chuckle.
  3. ASRDogman
    ASRDogman Senior Member
    6,043
    3,243
    Take a large pry bar and put it through the pully against the block to hold it still.
    I don't remember what the torque is but it's not high. That's what I did.
    Tombukt2 likes this.
