Harmonic drone while driving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gbru316, Jun 28, 2014.
  1. gbru316
    gbru316 Junior Member
    Lancaster, PA
    Started a few days ago. Seems to originate in the front passenger side. There's a slight noise at all speeds but around 40, 60 and 80 it seems to resonate.
    -Shifting to neutral doesn't affect it.
    -Hitting the brakes only affects it by slowing the car down out of the resonant zone.
    -Rotated tires, no change.
    -No lateral "play" in the wheels when I rotated the tires this morning.
    -It seems like making turns at speed might have --some-- affect on it, but very slight. Slight enough that I could be imagining it. I haven't noticed a decrease in fuel economy.
    -Tires are worn, although not down to the wear bars yet. Will be replaced at inspection.
    It was mentioned that new brake pads would be in store during the last inspection. Front pads still have between 1/8" to 1/4" left. They also mentioned machining the rotors. That being said, the pads looked like they are riding on the rotors. Could this be causing the ringing I'm hearing? Probably unrelated, but a new front left strut is also in the works per last inspection.
    Water pump, drive belt and coolant replaced at 78k per Toyota owner's site. (Bought it used at 100k)
    Car is a 2006 with about 175k on it. Most recently replaced the cat with an aftermarket last fall. I'm due for a state inspection in September, but I commute 700 miles a week, 95% highway. Any guesses so I'll have an idea how much lighter my wallet is going to be?
    49,725
    constant velocity joint?
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Wheel bearing is indicated there.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    Wheel bearing. Get on quiet road and make abrupt turns of the wheel right then left noting change of noise or pitch. The louder direction will be the side the car has a bad wb,
    For instance you say passenger side so if you turn left the noise should get louder as more load on the wb.
    WB's are common on Prius.
