HARNESS AND CONNECTOR (INVERTER WITH CONVERTER ASSEMBLY - GENERATOR RESOLVER)
Discussion in 'Prius v Technical Discussion' started by Todd Hollman, May 1, 2021.
  1. Todd Hollman
    Todd Hollman New Member
    Colorado
    I'm not sure if I'm going down the wrong rabbit hole or not. Has anyone followed the test procedure for the
    HARNESS AND CONNECTOR (INVERTER WITH CONVERTER ASSEMBLY - GENERATOR RESOLVER) Where you are supposed to ohm out between A59-10 and ground? I've checked the resistance with 2 different meters, my fieldpiece measures 1.7k, my Fluke measures 80 ohms. I've verified meters using fixed resistors and both test the same. the only difference I can find is that the Fluke uses a 6 volts dc while the Fieldpiece is a low impedance meter and is only using 0.3 vdc. The instructions only say to pull the service grip plug, leave power switch off and unplug A59 from the inverter only, and says that a good test is 12+k, anything less replace the harness. I have determined that if I unplug all the ECUs that are connected and with none connected the test shows infinite to ground. I've recorded the different resistance reading as I plug each ECU connector back in. Has anyone done this test and what have you found? I'm hoping I don't have 3 bad ECU's (power management, Transmission, HV battery)
  2. Elektroingenieur
    2,515
    3,259
    Three Touring
    Could you give us some more context, please?
    The Repair Manual (more info) for model year 2012 Prius v cars (RM18M0U) has four different procedures that call for resistance measurements at connector A59-10, for diagnostic trouble codes P0A78-113, P3233-750, P324E-788, and U0110-159/-656/-657. Which procedure are you using, and what is the step number?
  3. Todd Hollman
    Colorado
    manual from eautorepair Mitchell1
    23. CHECK HARNESS AND CONNECTOR (INVERTER WITH CONVERTER ASSEMBLY - PCU
    FUSE)
    WARNING: Be sure to wear insulated gloves.
    a. Check that the service plug grip is not installed.
    NOTE: After removing the service plug grip, do not turn the power switch on
    (READY), unless instructed by the repair information because this may
    cause a malfunction.
    b. Disconnect connector A59 from the inverter with converter assembly.
    c. Measure the resistance according to the value(s) in the table below.
    Fig. 172: Checking Harness And Connector (Inverter With Converter Assembly - PCU Fuse)
    Courtesy of © TOYOTA, LICENSE AGREEMENT TMS1002
    Standard Resistance
    Tester Connection Switch Condition Specified Condition
    A59-10 (+B) - Body ground Power switch off 10 kΩ or higher
    A59-9 (+B2) - Body ground Power switch off 10 kΩ or higher
    TEXT IN ILLUSTRATION
    *a Front view of wire harness connector
    (to Inverter with Converter Assembly)
    d. Connect the inverter with converter assembly connector.
    NG → See step 25
  4. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    What are the symptoms?
    Maybe the Inverter is out and that is covered under extended warranty.
  5. ChapmanF
    15,614
    Presumably the OP (who hasn't been back in a while) had some code implicating the MG1 resolver. That wouldn't be an issue covered by the IPM warranty extension.
    It would probably be something pretty simple though. I hope the OP eventually looked at a wiring diagram and got it sorted.
