Has anyone done a bore scope?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Isaac Zachary, Mar 16, 2022.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    2,287
    1,136
    I want to get rid of the oil burning on my Prius. After the PCV valve and with over 200,000 miles I believe the most likely cause is piston rings gummed up. But that could lead to cylinder wall damage. I'd like to see if the cylinder walls are ok before ordering just a set of pistons. A $2,000 engine block would be quite a bit jump, but that would be correct step if the cylinder walls are toast.
    I want to get a simple borescope and see what the walls look like without removing the heads. Has anyone else done this? Any suggestions on what tiny camera on a flexy stick to get?
  2. JC91006
    16,672
    8,518
    Here in this video has a camera for $139.00
    This video here has a good cheap device to take a look at the cylinders
    Isaac Zachary likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Rings have failed from crappy oil.
    Many a used G2 engine replaced on this forum from this very issue. Used G2 engines are plentiful and fairly cheap. Check local bone yards
    and ebay has many from $300 to $700.
    More members will come along with other outlets.
    Use the search forums link up top and search:
    engine replacement
