Has anyone flushed own inverter coolant?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tankyuong, May 21, 2013.
  1. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Any special way to cycle the fluid to get air bubbles out? Is the capacity 1/2 a gallon?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Capacity is 2.1 quarts (2.0 liters) according to the specs. I haven't done mine yet so I will be watching this thread with interest.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I have done both the inverter coolant and engine coolant. IIRC the amount of coolant for the inverter loop was pretty close to the spec amount.
    I pulled a vacuum on my coolant loops to avoid air bubbles so did not have this problem. Patrick Wong has an excellent thread on here about changing coolant and how to work out the entrained air. Try searching on here for his thread.
  4. tankyuong
    1,555
    660
    Central MO
  5. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Yes, I've done it before. The drain plug is a 10mm hex, and you'll need just over 2 qt of Toyota SLLC. In order to reach the plug, you will need to remove the undercover.
    Fill the inverter with as much coolant as possible, then turn the power on for about 1-2 sec and power off immediately. Top off the reservoir, as it will be very low. Repeat this two more times. After this phase, start the car and allow it to sit for about 10 min to ensure that the level no longer drops.
    The Gen III lacks a bleed valve, unlike the Gen 2. The system on the Gen 3 is also very quick and easy to bleed. I changed out my inverter coolant at 59k.
    iPhone ?
  6. tankyuong
    1,555
    660
    Central MO
    Good info, Critic and what about engine coolant flush?
  7. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Tankyuong
    hope this will help you my friend.
    V/r
    Khoi nguyen
    tankyuong likes this.
  8. tankyuong
    1,555
    660
    Central MO
    Lifesaver thanks Nguyen
