Has anyone found a replacement FOB case?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Robmoo, Aug 1, 2013.
  1. Robmoo
    Robmoo Junior Member
    55
    2024 Prius
    Standing in line at Autozone I decided to see if I could open my FOB without watching a video on how to do it. Pulled out the emergency key and there was the groove to open the fob with the tip of the key. I was surprised how small is the circuit board. The fob is large and bulk compared to the board. Has anyone found a replacement case that is smaller? I'd try just putting the board in my wallet if the thing wasn't so expensive.
  2. guicide
    guicide Junior Member
    New Hampshire
    No, but while mine was disassembled I spray painted it Barcelona Red.
    SAMSUNG-SGH-I317 ? 2
    32kcolors likes this.
  3. sushiDot
    sushiDot Junior Member
    36
    I found one that I really enjoy...its not a FOB per say, but its a cover that goes over it.......
    BTW...what does the key do that is built into the FOB?
    If you go on AMAZON and search for item B007FUVQCO you will see it
  4. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    The mechanical key is a backup to your SKS fob. If your battery dies, you can unlock the door manually and hold your SKS fob up to the Start button for several seconds then start the car.
    SCH-I535
  5. xliderider
    8,140
    3,274
    Honolulu, HI
    To the OP, there was a thread here about the Lexus card key. It is about the dimensions of a credit card, but not as thin. I'm not sure if anyone has been able to get one reprogrammed and working on the Prius.
    SCH-I535
  6. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    Try plasti-dipping it :eek:
  7. Robmoo
    55
    2024 Prius
    If I need a new fob I might try that Lexus card.
