Has Anyone Installed a Dash Cam?
Discussion in 'Prime Accessories and Modifications' started by geguia, Jan 26, 2017.
  1. geguia
    geguia Active Member
    209
    108
    los angeles
    wondering how the install went and where did you wire it to?
    Thanks
  2. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    I do. You need a 3.5 meters power cable. Use the 12V socket at the back seat. Run the wire through the floor and tuck it inside the seams around the windshield. I use the front seat 12V port for cellphone charging.
    Last week a cop pulled over the car for "not stopping in front of a stop sign". Good see u on court. Let's see how you face the video stream. Thinking I can't defend myself? Think twice.
    douglasjre, Vacaboca, muleman and 6 others like this.
  3. geguia
    209
    108
    los angeles
    Glad you have that footage!
    BTW which cam do you have? i have a A119 on order.
    Can you take a photo of your set up when you have a chance? thinking of having the cam on the left side of the mirror.
    Did you pull off the paneling off around the windshield in order to hide the wiring?
  4. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    Mine plug into the Prime ODB for power. However in my 2014 prius dashcam, I have to tap a circuit from the fuse box below the steering for older dashcam.
    iPhone ?
  5. huskers
    huskers Senior Member
    2,544
    2,486
    Nebraska
    Will it be on Judge Judy?
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I have two WheelWitness dash cams, one for the front and one for the rear, I haven't installed them yet (was on my 2015 PIP) Was concerned about dash cam blocking whatever is behind the rear view mirror. No problem with rear dash cam because the lower window is simular to the PIP's lower window. I am open to any suggestions on the installation of the front dash cam tho.
  7. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Seems to me I've read somewhere in the manual that at least for the Advanced model the forward facing camera is recording in case of an accident. I don't know how you can get to it however.
  8. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    I havent reinstalled my dash cam since I pickup my Prime. Ive also been wanting to install the homelink mirror too
    priuscatprimeguy likes this.
  9. EspressoFueled
    EspressoFueled Junior Member
    23
    53
    Napa, CA
    I just installed a Viofo a119 last night in the center of the windshield (to the right of the built-in camera and directly under the humidity sensor). For now I went with the fast and dirty install, so the USB cable simply runs straight down the dash and under the passenger seat to the rear of the arm rest where the 2nd 12v port is located. Eventually I'll get around to routing the cable in a less conspicuous way...
  10. geguia
    209
    108
    los angeles
    Running the Thinkware F770 - havent hardwired it yet nor installed the rear camera yet. Works great though
  11. jbhybrid
    jbhybrid Junior Member
    16
    I want to wire in a dashcam, but am not sure how to route the wires. On my old car it was simple to run a wire down the side of the windshield inside the otherwise-empty A pillar. I haven't poked around there on the Prime, since I'm not familiar with curtain airbags. Is there switched 12V somewhere inside the overhead light assembly? I wish there wasn't so much blocked area around the rearview mirror, I can't place the cam where I'd like.
  12. YPizza
    YPizza Junior Member
    San Antonio
    Here's how I routed the 15 ft. USB cable for this basic Aukey dash cam:
    Pushed up into the headliner
    Out and around the A pillar above the airbag panel, and into the inner rubber moulding of the door frame
    Kept going down the front of the door frame and back into the cabin at the bottom of the glove compartment
    Around the back of the passenger footwell through a few loops behind the glove compartment
    Pushed the cable between the plastic trim and the center tunnel. You can see a short segment of cable showing between the front segment and where the wireless charging pad begins
    Then up next to the passenger seat and into a dual USB port 12V adapter
    If you have a slightly longer cable, it could keep going further back to the rear 12V outlet like EspressoFueled did.
  13. jbhybrid
    16
    Thank you for posting the detailed photo set. It's this one in particular I'm wondering about, what are the implications of running the wire around the A pillar this way, in case of a curtain airbag deployment. I understand the airbag extends to either side of that point (?)
    For example, the "small overlap front" airbag deployment photo at the IIHS website: Vehicle details
    #13 jbhybrid, Feb 23, 2017
    Tyfly and YPizza like this.
  14. YPizza
    San Antonio
    Thanks for those helpful crash photos. I didn't realize the curtain deployed above that seam too. I'll try routing the cable further down the side of the windshield before looping around the base of the A pillar instead.
  15. YPizza
    San Antonio
    It's a tight fit but there's some room between the A pillar and windshield to hold the cable in place, and then between base and dash before going into the door frame as before.
  16. CaliforniaPrius
    313
    201
    Alameda, California
    It is exactly the way I did mine. The cable needs to be very long.
  17. SubPrius
    SubPrius Junior Member
    31
    See below.
  18. SubPrius
    31
    I have a $75 Mobius camera in my Gen 3. Small size, loop recording, and auto-on means that I don't pay attention to it, until I occasionally lean over to check the rear LED to ensure it is recording. Does get warm though.
    Do mount it with a camra-type mount so that you can swivel it when necessary to record a tailgater, side-swiper, or policeman.
  19. Prime213
    Prime213 New Member
    Washington
    Spytec A119 Dashcam
    i Bought One Of These On Impulse. I Dont Know Anything About electronics, but I Am Hoping To tap Into The Map Light Power.
    Anyone Know How I Can Disengage The Map Light Cover To Expose The Circuit?
    Also, Am I Going To Seriously Fry The Circuits By Doing This?
  20. BlacksmithTB
    BlacksmithTB Junior Member
    Portland OR
    I use a Mobius as a 'dash-cam' on my bike, I believe if you're keeping it plugged into USB non-stop they recommend you swap out the LiPo battery for a pair of big capacitors - search on the Mobius Actioncam site (or Amazon) for "mobius super capacitor battery replacement"
    (which shouldn't be hard, I replaced my LiPo with a new, slightly higher-capacity one easily a year or so ago)
