Has anyone put spacer "just" on the rear tires?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by BSBMPG, Jan 25, 2013.
  1. BSBMPG
    BSBMPG Junior Member
    24
    Orange County
    I am looking to put the Prius 5 17" OEM wheels on my 2010' and I am checking to see if you think I can put 10mm or 12mm spacers just on the rears? Would this make the front & rear offset too wanky? The fronts are pretty flush but the rears clearly are not. Any info or suggestions will be appreciated.
  2. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    Many put spacers on only the rears for the very reason you mentioned.
    FYI, it's the Prius 5 now, not the V. Ppl tend to get confused with the Prius v. ;)
  3. BSBMPG
    24
    Orange County
    Noted. Thanks
  4. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    I had 5mm. spacers in the rear w/my 17" aftermarket wheels. I have since taken it off since I'm not as concerned w/ the flush look.
  5. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    I have 13mm installed in mine :)
    mbox likes this.
  6. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Hello Sir,
    Do you need to use extended length lug nuts? Is the screw long enough to accepr the 5mm extension? Thanks.
  7. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    You're good with 5mm. If you want more than 5mm, you should replace it with extended lugs.
    ahmeow likes this.
  8. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Thank you Sir. WIll get them from ebay. Just for the rear tires.
