Has anyone raised the front and put it in "D"?
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Sep 18, 2015.
  1. bwilson4web
    16,359
    One of my thoughts is to spoof MG2 to the car so I can trick the inverter into generating a 120 VAC, 3-phase and/or two, 120 VAC, 2-phase power outputs. One of the first tests is to see if the car throws a code if the front is lifted off the ground, rear wheels blocked, and put the car in "D".
    Does it throw a code?
    Before running the experiment, I thought I'd ask,
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Probably not very helpful but with gen 2 in maintenance mode you can do that and it doesn’t cause codes.
  3. E46Prius
    E46Prius Active Member
    314
    220
    Costa Mesa
    It'll likely illuminate a traction control light due to the relative speed difference of the front and rear wheels. But that's not a big deal. It'll disappear after a short drive.
  4. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    ABS will code but I'm pretty sure the wheels will keep on spinning.
    Use this http://amzn.com/B000XSEBEK if cruise control disables itself because wheel speed sensors not reporting properly.
