Has anyone swapped out the elector motor?
Discussion in 'Gen 2 Prius Main Forum' started by tnthub, Dec 23, 2010.
  1. tnthub
    tnthub Member
    519
    Brunswick, Maine
    I am just starting my research since we just bought a 2007 Prius. I am curious if this has been done successfully.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Which one?
    Do you mean has anyone replaced the transmission or has anyone actually replaced one of the motors from within the transmission? I guess it would be an difficult thing to do.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The two hybrid three phase AC motor/generators are mechanically and electronically integrated into the HSD. You can't "remove and substitute" them. At any rate, where would you find a 520V three phase motor generator that runs at 90% or better efficiency to put in even if you could?
  4. tnthub
    tnthub Member
    519
    Brunswick, Maine
    I have this setup in my driveway but it needs a new body to be street legal...
    I'm just researching.
    Performance Highlights and Specifications
    Max. Horsepower: approx. 300 (430 - 500*) HP
    Max. Torque: approx. 400 (600 - 660*) ft-lb
    Weight: approx. 5000 lb
    Length: 16 ft
    Width: 6 ft 2 in
    Height: 42 in
    Ground Clearance: 5 in
    Acceleration, 0 - 60 mph: 7 - 9 sec (5 - 7 sec*)
    Acceleration, 1/4 mile: 14 - 16 sec
    Acceleration, 1/4 mile top speed: approx. 97 mph
    Top Speed: approx. 140 - 160 mph (about 100 mph in 3rd gear)
    Gas Mileage Equivalent**: 60 - 100 mpg (about 3-5 cent/mi)
    Range: 100 - 140 miles per charge
    Recharge time: approx. 6 hrs.
    Clutch: Centerforce double sprung
    Transmission: Camaro high performance 6 speed
    Regenerative Breaking System: 10 KW
    Body: Composite rigid foam and fiberglass
    windshield: 1/4" Lexan
    Batteries: 40 8V deep cycle Trojan
    * specification with new Zilla 2000 amp water cooled controller, original
    specifications based on DC Power 1200 amp controller. Range specified based
    on 160 - 180 V battery voltage.
  5. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Here are the Gen II (left) and Gen III PSD/MGs in their naked beauty:
    This shows how the Gen II is imbedded in the "transmission" housing:
    Seems like there is very little room/chance for experimentation here...
    never mind purely electrical considerations and computer control
    algorithms.
  6. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Of course you could put yet another motor driving the rear wheels of a Prius (and another battery pack) as in a Highlander Hybrid;
    JeffD
  7. bisco
    49,443
    you have a talent for writing sir, i enjoyed your wordsmithing, thank you.:)
  8. tnthub
    tnthub Member
    519
    Brunswick, Maine
    Thanks guys. Not exactly what I was hoping to see...
    In Maine, it seems nearly impossible to obtain insurance at reasonable rates on a full electric car that is not a "name brand". I was hoping to be able to utilize the Prius as a host.
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Have you considered a 2000-2006 Honda Insight? The IMA motor/generator is a standalone piece of hardware, curb weight is 1000 lbs less (aluminum!!!), and you still get EPS. Given the major problems with short service life of IMA batteries, these cars often come up for sale for $3000 or less.
  10. black_jmyntrn
    black_jmyntrn Senior Member
    1,300
    338
    2013 Prius Plug-in
    any prius phev is the best to start with imo
  11. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    You are right of course, but the PHEV did not exist when this thread started.
