Has anyone tinted their windows?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by fullylaced1, Jun 15, 2023.
  1. fullylaced1
    fullylaced1 Junior Member
    31
    Los angeles
    What kind of tint did you guys get and how much did it cost?
  2. BiomedO1
    BiomedO1 Senior Member
    4,140
    2,170
    SacTown, Ca
    Go with the ceramic tint; it stops the heat from pushing through the glass.
    back around 2012-2013, on my Prius C it was $125. 4 doors and rear glass - shopping around.
    On my 2021 last year it was $275, 2 rear doors, rear glass and rear deck glass. That wasn't really shopping around and the summer heat here was really pissing me off; but it was ceramic tint. Rear passengers commented that the sun no longer burns the back of their neck, with that tint.
    Hope this helps
    Deb Rothschild and fullylaced1 like this.
  3. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    I got the dealer to do mine. I would expect to pay around $250-300 to do it otherwise.
    Deb Rothschild likes this.
  4. 2023p
    2023p Active Member
    161
    103
    Here
    2023 Prius
    35% all around, ceramic Xpel 88% IR rejection. Not on windshield, maybe in future, will be not tint on that though.
    Was under 4 bills out the door. After it's done check all your seals on every window - in my opinion - because I noticed some of it was not tucked in properly and it was causing a lot more wind noise.
    That was on the front tiny window bear the side mirrors, in the very front towards the hood part. The trim seal rubber parts were bowed completely out at the corner. Tucked it in and noticed (maybe placebo) much less wind noise.
    BiomedO1 likes this.
  5. BiomedO1
    4,140
    2,170
    SacTown, Ca
    Yep, you need to check their work. The shop that did my 2021 had to redo two windows - found wrinkles. I'm normally not that fussy; saw them before I left the shop. The guys at the shop swore to me that they would settle out; well they didn't - so it was redone a week later.
    2023p likes this.
  6. Jim Call
    Jim Call Active Member
    107
    114
    Asheville
    2023 Prius
    P1.jpg Tinting was the 1st thing I had done to my new XLE. $350 OTD, Ceramic Expel dark tint. Love it![​IMG]
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Just had my Corolla done. Ceramic $300 installed and transferable.
    15% on the back window and rest 30% with a 15% strip along the top of the windshield.
    When I buy a new car its the first thing I do.What a difference in the way the car looks.
    2023p likes this.
  8. PixelRogue
    488
    86
    US
    While I do not recall the tint level, I had the same tint all around...looks like while parked. When driving all is fine UNTIL nighttime... the front windows are extra dark at night.. next time around a light tint on the front windows.
  9. mountaineer
    mountaineer Active Member
    146
    115
    Hamilton, ON
    2019 Prius Prime
    A real pet peeve of mine is window tinting that makes drivers invisible. There's good reason this is illegal in most jurisdictions!
    Pedestrians, cyclists, and other drivers need to be able to make eye contact with the driver of a vehicle, at intersections and other times it's important to figure out the intentions of a driver.
    I've heard stories of drivers from other provinces getting tickets in Quebec, where they regularly enforce window tinting laws. In Ontario 70% VLT (visible light transmission) should be permissible on front side windows – but it's complicated.
    Mendel Leisk and leftbrarian like this.
  10. BiomedO1
    4,140
    2,170
    SacTown, Ca
    I live in one of those states, where it's illegal to tint the driver's door forward, that's both front doors. Most shops are willing to do the front doors, but make it clear that they're not responsible. They will charge you to remove it, if you get a "fix-it" ticket.
    It's always a good idea to limo (black-out) tint the rear doors and go with the lightest tint they have for the front doors. With that contrast, cops will do a double take; but I haven't been stopped for window tint in over 20 years - Knock on wood:)... So, if you move to a neighboring jurisdiction where that's illegal, you're less likely to get into trouble.
    Hope this helps....
    Agent337, daisy555 and mountaineer like this.
  11. dlford
    dlford New Member
    Arizona
    2023 Prius Prime
    SE
    I got GeoShield ceramic, 35% front side windows and 5% back and back side windows, $345 installed.
  12. Jim Call
    107
    114
    Asheville
    2023 Prius
    River Prius 2-2.jpg River Prius 2.jpg Purdy Prius.jpg Purdy Prius.jpg Ceramic tinted and smoked window guards. Can't beat the look!
    #12 Jim Call, Jul 16, 2023
  13. 5THGENPRIME
    5THGENPRIME New Member
    Bay Area
    2023 Prius Prime
    XSE
    @Jim Call what % did you get?
    Anyone tint their front windshield?
  14. MaxT
    MaxT Junior Member
    27
    45
    Georgia
    2023 Prius
    35% on mine, $300 at a dealer and they installed Nitrogen for the tires.
    Also get a lifetime guarantee on the tinting.
  15. 2023p
    2023p Active Member
    161
    103
    Here
    2023 Prius
    Have not, but plan to with the xpel ceramic at 70% or higher, so it's not noticable probably but still rejects a lot of IR
  16. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Went with full ceramic including clear on the windshield. After 4 consecutive 100F degree days recently, trying to cut down on the heat.
    2023p likes this.
  17. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    I live in California too. Its not illegal to tint the front windows. Max is 88% light in, or 70% VLT if its already got a factory tint.
    https://www.tinting-laws.com/california/
  18. Dougle
    Dougle New Member
    2023 Prius
    I'm in the same environment and looking to get Ceramic as well. What % did you do on your windows and any trouble at night? Your look is exactly what i'm going for, lol.
  19. Agent337
    Agent337 Member
    50
    27
    Orange County, California
    2023 Prius Prime
    SE
    The very first mod I did to my car was the window tint. Hot sunny summer days gave me a lot of incentive to do so. I had ceramic tint done on all the windows, 20% for the rear windshield and rear passenger windows, and 30% for the driver and passenger windows.
  20. yarrh
    yarrh Junior Member
    17
    NYC
    2023 Prius
    Limited AWD-e
    Xpel XR Plus
    70% front windshield
    35% sides and rear
    Our cars’ front windshields let a lot of heat in. Highly recommend 70% ceramic for the front if nowhere else for those who have hot summers.
    The glass roof also lets a lot of heat in. Has anyone tinted their roof? I’m hesitant owing to reports of Tesla roofs cracking after being tinted because of “trapped heat.” Although I suspect it’s due to stress caused by a difference in rates of thermal expansion btwn glass and film across their sheer size. Our roof panes are much smaller are divided in two sections.
