Has anyone tried replacing the 12 volt battery with a LiFePO4 12.8 V battery?
Discussion in 'Gen 4 Prius Technical Discussion' started by GoodOldBob, Dec 1, 2023.
  1. GoodOldBob
    GoodOldBob Member
    67
    25
    Mena, AR
    2020 Prius
    L Eco
    I am interested in substituting a 50 or 100 AH 12.8 Volt LiFePO4 (LFP) to replace the Lead Acid battery. Mainly for the increased storage capacity and increased cycle life. Has anyone tried it yet? Did it work OK? Please let me know if you have done it.
    --GoodOldBob
  2. sylvaing
    sylvaing Senior Member
    1,210
    514
    Does that battery has its own heater to allow it to charge below freezing? Charging a frozen Lithium battery will damage it.
    Isaac Zachary likes this.
  3. GoodOldBob
    GoodOldBob Member
    67
    25
    Mena, AR
    2020 Prius
    L Eco
    Most quality LFP battery management systems include a low temperature cutout that blocks charging when too cold. Remember that the engine bay of the Prius doesn't stay below freezing for very long after the engine kicks in.
    51,903
    Pretty sure this has been done multiple times, search google with Prius chat
  5. sylvaing
    1,210
    514
    Oh, right. The engine in the standard Prius is used quite often. I guess that could be different in a Prime.
  6. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    You may want to investigate the charging requirements for each of the batteries. The charging algorithms for a lithium battery are significantly different than those of a lead acid battery. A starting point might be The Battery University (yep, it actually exists). Or, you could just rely on the opinions of folks who don’t even know there are significant differences between the two (like PC egineers (misspelling intentional) ;)
    GoodOldBob likes this.
  7. Me_
    Me_ Junior Member
    32
    MD, USA
    2018 Prius
    Three Touring
    That question has been answered. Do a google search.
    In short due to a difference in the resistance between a standard 12v car battery and a lithium-ferric 12 v battery, you will burn the alternator; seriously burn it..
  8. sylvaing
    1,210
    514
    Good thing the Prius doesn't have an alternator then ;)
  9. SWHPBT
    SWHPBT New Member
    My understanding is the Prius 12V battery is charged via a DC-DC converter from the hybrid battery and there is no 12V alternator in a Prius.
    Doug McC and GoodOldBob like this.
  10. sylvaing
    1,210
    514
    Your understanding is correct.
    Doug McC likes this.
  11. GoodOldBob
    GoodOldBob Member
    67
    25
    Mena, AR
    2020 Prius
    L Eco
    Which is why I ignored the reply left by "junior member" ME_ . I assumed he/she/it wasn't fully appraised of the facts about the Prius electrical system. Thanks for making them aware.
    GoodOldBob
  12. Robert21PrimeLTD
    Nashville
    What about a AGM (absorbent glass mat) battery? Would that be okay?
    douglasjre likes this.
  13. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    Not in a 2020 (contrary to what some will tell you here). One, the charging algorithms were set up for lead-acid (meaning you will shorten the life of the AGM); Two, you won’t REALLY gain anything; Three, you will waste your money; Four, there is a slight (emphasis on “slight”) chance of damaging the ECU system (it’s assuming you are smart enough to read the owner’s manual and not to replace the battery with the wrong type).
  14. GoodOldBob
    GoodOldBob Member
    67
    25
    Mena, AR
    2020 Prius
    L Eco
    My original idea is to have a car that is totally free from ancient lead-acid technology and all it's drawbacks. Even if the charging algorithm isn't optimal, a less-than 100% charge would be fine and not shorten the LiFePO4 cycle life of 3000 to 4000 full charge/discharge cycles. And with that kind of performance, the 12 Volt battery could be expected to outlast the HV traction battery.
  15. Robert21PrimeLTD
    Nashville
    My AGM question is because my sister, who has a non-plugin Prius, had her 12v battery die during Covid lockdown and had to get a jump start and then drive around while braking to charge the 12v. Is my plugin different? Will plugging in the HV battery charge or help the 12v battery? I'm new to hybrid technology and am not sure of how the charging systems work.
  16. GoodOldBob
    GoodOldBob Member
    67
    25
    Mena, AR
    2020 Prius
    L Eco
    I'm told the plugin Prius charges both the HV Traction battery and the 12 Volt Accessory battery when plugged in and charging.
    Robert21PrimeLTD likes this.
  17. sylvaing
    1,210
    514
    Yes, your plugin will charge the 12V battery at a voltage of 12.8V while charging. It will also charge the 12V battery at a voltage of 13.5V when plugged in, not charging and the heater elements are actively heating the battery pack because it got below 2°C.
    vvillovv and Robert21PrimeLTD like this.
  18. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    Are both those voltages consistent for the span of times for both charging and battery heater warming the pack?
    And if you ever use pre-conditioning and monitor the 12 volt batteries voltage, do you also see a similar charge rate during that 10 minute session?
    I'm sure you've noticed all the complaints about how the Gen 4 and 5 plug-ins don't charge the 12 volt battery at all while plugged in and only charge that 12 volt battery while in Ready Mode. and that rumor spreads pretty fast. Possibly due to the cars may not always charging the 12 volt battery when some owners take a look at their 12 volt battery voltage one time and think they've discovered a big problem. Than start looking for the parasitic draw which keeps the 12 volt battery at their observed SOC.
    My 12 volts SOC is typically around 12.2 volts, until I post that stat here and than next time I look the voltage is around 12.5 ... lol
    #18 vvillovv, Mar 24, 2024
  19. RandyPete
    RandyPete Active Member
    403
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    SOC is a power rating in percent of the battery watt-hour rating. It is not the voltage of the battery.
    Watt-hour=VoltXAmp-hour
    A 12 volt 100 amp-hour battery is a 1200 watt-hour battery (12Vx100Amp-Hour battery rating = 1200Watt-hour battery capacity)
    #19 RandyPete, Mar 24, 2024
  20. vvillovv
    4,321
    1,510
    NY
    What are you trying to say?
    Is your post supposed to have something to do with the question I asked @sylvaing about his 12 volt battery readings?
