Has anyone upgraded the back up camera
Discussion in 'Gen 4 Prius Accessories and Modifications' started by 2020XLEAWD, Jul 30, 2022.
  1. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    Has anyone upgraded the back up camera?
    I don’t wanna change the screen I just want to change the back up camera. Has anyone done this? I feel like the camera resolution is really terrible but the screen is good enough to display something sharper.
  2. beef jiggles
    beef jiggles Member
    135
    34
    Colorado
    Not worth the time, effort, or frankly... the discussion. You're backing up a tiny car, not streaming Pornhub in 4K. I don't understand why everyone has to be staring at a screen 24-7. Just use your mirrors! The camera is good when parallel parking and you want to get ½" from another car... otherwise? Useless.
    Diemaster likes this.
  3. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    Please no stupid unhelpful comments
  4. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    It's not a stupid question. I use the back up camera everyday in all kinds of conditions. I upgraded the backup lights so when I’m camping, I can see more. I don't want to run into shit and gouge my car. Now I want to see more detail on my screen. You clearly haven't upgraded the camera. You’re just giving some silly opinion. Get the **** off the thread you unhelpful POS
  5. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    Are you sure a better camera would provide a better image on the screen? To connect up to screen I would think you would need wiring diagram of current plug and know what wires to connect to on plug also. I haven't heard of anyone here changing camera though, but would be interesting to see what happens. Found this kit for you, not sure if this kit has the cameras you want though.
    TOYOTA PRIUS OEM Integrated Backup Camera System | Buy | OEM Integrated Backup Camera Systems | Car Integrations
    alanclarkeau likes this.
  6. Leadfoot J. McCoalroller
    7,173
    6,719
    Pennsylvania
    2018 Prius c
    You could upgrade the camera, but then you'd have to upgrade the head unit too. It doesn't have an input for a hi-res camera. It would have to be a different signal type to support hi-def, and that might require different wiring from front to back.
    So... not impossible, but it would be a big commitment with lots of other changes required.
    jerrymildred likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    What leadfoot said. Feeding a 4K source into a 720P display, for example, won't give you a sharper picture.
    I agree that the image is pretty bad, especially in low light. Most times, it's fine for its purpose, which is to avoid running over a kid. I'd think about an aftermarket camera and display like the ones that go on your rear view mirror.
    TGrracie and alanclarkeau like this.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    I'm sure it would be better with a better camera. It's actually very good in daylight, with the moving guide-lines. But at night - forget it - I put my side windows down and use the mirrors.
    If you find a better camera, please let us know.
    2020XLEAWD and jerrymildred like this.
  9. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    I think you’re right. The prime has the 11.6 HD screen. I have the base small screen. WVGA something like 800x480
  10. alanclarkeau
    7,044
    7,584
    Except that the camera is brilliant in good light - just poor in low-light, or no light.
  11. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    Not worried about wiring or install. I got a wiz who did my stereo and dash cam
  12. Leadfoot J. McCoalroller
    7,173
    6,719
    Pennsylvania
    2018 Prius c
    The complaint seems to be same or similar to a very common one, that the NTSC-format video from the stock camera is poorly scaled by the head unit for display on the (much higher resolution) XLE screen. Nothing to do with exposure control.
  13. MIkeDr
    MIkeDr Active Member
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    You should drive a Prime once. While the screen is indeed huge, the backup camera view takes up just the top 25% of the display, with the rest blacked out, limiting your view to the same as the base screen size. It’s amazingly bad.
  14. jerrymildred
    11,511
    14,113
    Tampa, FL
    We have the small screen on our regular Prius and the 11.6" screen on the Prime. The Prime isn't any better as far as I can see. In fact, the small one might be a tiny bit sharper.
    It is amazingly bad, but I see no benefit to having the full 11.6" screen available to the camera just so we could see more of the sky and maybe even under the car. More up and down range is not any help at all. It would help to have designed it with a landscape orientation for the screen rather than the stupid portrait orientation. Then you could actually increase the camera resolution to something that would show some detail.
  15. MIkeDr
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    [QUOTE="It is amazingly bad, but I see no benefit to having the full 11.6" screen available to the camera just so we could see more of the sky and maybe even under the car. More up and down range is not any help at all. It would help to have designed it with a landscape orientation for the screen rather than the stupid portrait orientation. Then you could actually increase the camera resolution to something that would show some detail.[/QUOTE]
    fair point. My bigger issue with the Prime screen is that CarPlay is similarly limited to just that too 1/4 or 1/3 of the screen. Other makers, like Subaru, that have vertically oriented screens use the entire screen for CarPlay.
    even the Prime’s own navigation screen is subpar, wasting an inch on the top for a fixed image of a car.
  16. jteran5
    jteran5 Active Member
    411
    202
    2019 Prius
    XLE AWD-e
    I'd like to chime in here. I had an aftermarket headunit with an aftermarket camera and it was super clear. Unfortunately my car was totaled and I'm waiting for a new car. I'm thinking about trying the below in order to avoid having to rewire the new reverse camera.
    You could theoretically use any aftermarket camera with the below adapter harness.
    https://a.co/d/gcYBdlI
    A lot of aftermarket headunits retain oem rear camera functionality so I figured I could just use this adapter to use the stock wiring already there.
    I'm assuming if you have the stock headunit, you would have to run a CVBS camera like below to connect to the harness. It's a nice wide 180 wide camera and has the option to remove the parking lines from the camera and allow you to use the stock lines from the stock headunit.
    https://a.aliexpress.com/_mON27RK
    And to finish it off, use the below bracket to keep the stock location and angle for the aftermarket camera. The clip looks just like the one that was on my 2019
    https://a.aliexpress.com/_msGUvri
    These options will be limited by the resolution of the headunit tho which I'm not sure of but at least you get a wider view camera
    Mambo Dave and 2020XLEAWD like this.
  17. MalachyNG
    MalachyNG Active Member
    300
    221
    Northern NY
    2022 Prius Prime
    it's not completely static, the little headlights turn on when it's dark out
  18. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    The best car camera I've ever seen - not for resolution, but for its uses - was on Honda Accords. Three completely different camera views to choose from, ~170 degrees (sweeping the lane of a parking lot for example), narrower-focus, and straight-down. With the straight-down mode I could park an Accord within less than once inch from a metal pole or another bumper.
    The turn signal camera was also excellent. This was all back in 2012.
    I don't think they do that anymore. Toyota 2019? Nah, bro, we don't even want to be considered 'good.'
  19. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    You could always swap in brighter LED reverse lights so that its brighter and improves the image.
  20. jteran5
    411
    202
    2019 Prius
    XLE AWD-e
    This is the wideview camera I had on my 2019. Its a 175 degree horizontal view. Very nice for when backing out of a spot and can see pedestrians or other cars that would otherwise be in my blindspot IMG_20220423_101018.jpeg
    2020XLEAWD and Storm88000 like this.
