Has anyone used the windshield de-icer switch yet?
Discussion in 'Gen 5 Prius Main Forum' started by Humble Bear, Jan 22, 2025.
  1. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    I live in Southern California and haven't gotten a chance to use the windshield de-icer switch and wonder if those of you live in the colder climates have used it yet? Does it really work? It's the farthest right switch amongthe 3-switch cluster to the left of the steering wheel that has a symbol similar to windshield defroster. It's in our owner's manual page 363.
  2. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    I live in FL but twice drove to New York in snowstorms this winter already. As far as I can tell, it worked really well - when I had it switched on I had no issues with ice on the windshield or the wiper sticking, etc. But it turns off after awhile so you have to keep turning it back on - like the rear defroster.
    Of course my wiper fluid froze below around 28 degrees. If only my dealer down here would not refill it with the stuff that isn't rated for super cold. At least I assume that is the issue since I use the good stuff when I refill it.
  3. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    Sounds amazing to me, also amazing that my base vehicle comes standard with this feature. I wonder if it's good for defrosting? I need to try it next time. BTW, owners manual says it will turn off after 15 minutes automatically.
    52,693
    is it more than just blowing hot air on the windshield?
  5. mva
    mva Active Member
    171
    100
    B.C. Canada
    2024 Prius Prime
    SE
    Nope, it’s heat wires down where the windshield wipers park to warm up the blades.
  6. ChapmanF
    18,889
    I've seen stick-on versions of that on sale in truck stops. Back when there used to be a whole season of winter here, I had flirted with the idea of buying one for the car and seeing how well it worked. Seems like it would be pretty easy to do, with the dash top off, sticking it down low on the windshield where the wipers end up.
  7. Paul Gregory
    Paul Gregory Senior Member
    2,310
    607
    Alberta
    2024 Prius Prime
    XSE
    I use it all the time, but that goes without saying in this climate, where your wipers are more likely to be frozen in place every time you get in your car. It works quite well, if you're patient. Sometimes it takes 2 or 3 cycles, because it keeps shutting off. I like that it allows me to use the same wipers all year around.
  8. bisco
    52,693
    that's pretty cool! (or warm)
  9. Blackat
    Blackat Active Member
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    I didn't know about that switch, thanks!
    Could have used it many times, now I know!
  10. SFOcman
    SFOcman Junior Member
    Pinole CA
    Use it one in awhile to fast defrost also. Have not had ice buildup yet to try it out.
  11. Toyotaworker
    Toyotaworker New Member
    2024 Prius Prime
    Daily and it works great
  12. Cactus
    Cactus Junior Member
    32
    Mountville PA
    Confirmed it works nicely. PA winter has been non stop since December.
