Has anyone....
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Gas Mizer, May 20, 2014.
  1. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Considered adding an additional traction battery and wiring it in series?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    It's not that easy. A series connection just freaks out the electronics.
  3. pauerbach
    pauerbach Member
    101
    34
    I'll take "Void My Warranty" for $2000, Alex.
    Seanzky, acceleraptor and Burna J like this.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  5. bisco
    49,442
    not successfully.:p
  6. mrbigh
    3,686
    699
    Long Island, NY
    I do not think that Enginer is still in the business of PHEV assemblies and accessories
  7. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    Batteries increase the potential (voltage) along a circuit path. More specifically, they establish a potential difference at their terminal points. I believe my traction battery is something around 207V. Where it currently exists would also expect 207V. Wiring a second battery in series with it, into the same point in the circuit, would then put 414V at the positive terminal (with respect to the ground) instead of 207V. Not sure that's so good for the rest of the system.
    I imagine what you mean is wiring it in parallel, similar to the way car audio enthusiasts might wire in a second 12V in parallel (with or without circuit modifications) for additional power.
  8. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    I guess I should disclose what I'm pondering in my little mind. I'm thinking that perhaps if I add more batteries, I could possibly power the rear wheels as well. I was thinking of picking up a Gen I Prius to tinker with. And I'm not concerned with mpg in this scenario.
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Why not start with a hybrid highlander, it already has an electric rear wheel drive
  10. Mr.Electric
    Mr.Electric Member
    287
    102
    San Francisco
    I like the idea. I saw a golf cart rear end that seems like it would be a good start for adding rwd. I wonder if leaf springs could be used in the rear?
  11. fuzzy1
    10,167
    I'm not grokking how adding a second battery in series with the original, has any relationship to powering the rear wheels.
    Without changes to the battery control electronics, this series connection will end up running the battery cells at half their usual voltage, where they have little usable capacity. Adjust the battery control to charge the cells to normal, and you risk blowing out everything tied to the battery set that is not rated to run at double the normal voltage.
  12. Seanzky
    Seanzky Member
    150
    28
    NY
    Has anyone here on PC actually done this? I searched but couldn't find any.
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Yes, back when there was no way to buy car from Toyota with a larger battery, many users did.
  14. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    There are various aftermarket shops that can convert your non-plugin Prius to a plug-in.
    One example- Upgrades | Boulder Hybrids
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    If you were seriously considering a project, I would not do it with a Gen 1. Gen 2 might make more sense.
  16. bisco
    49,442
    many have tried, many have failed.
    usnavystgc likes this.
  17. mrbigh
    3,686
    699
    Long Island, NY
    I converted my 2004 Prius on 2006 to a PHEV, I was one of the pioneers by those days. Then in 2010 it was called "TOTAL" loss by the insurance Co. I then transfered the PHEV equipment to a replacement 2008 until 2012 when I sold the vehicle. Everything was transferred again to a 2011, my wife current vehicle.
    So far, the PHEV equipment was used for about 76k Miles and still driving strong after some batteries maintenance.
    I started with few OEM Prius batteries assembly packs them migrated to LiPoFe4.
    Yes PHEV conversions can be done having in consideration a lot of patience and dedication; money was not an object for this working experiment but it was a lot of an investment.
    Seanzky likes this.
  18. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Excuse my ignorance, but what exactly does PHEV mean. Do you have any information on what you accomplished that I may peruse? :D
  19. mediahound
    903
    155
    I assume Plugin Hybrid Electric Vehicle.
  20. mrbigh
    3,686
    699
    Long Island, NY
    On my profile signature, on the BMS+ is an explanation of the system operation and all the gadgets needed.
    I will recommend you to purchase an already made KIT from a vendor and there are not many around.
