Has installed Cruise-control on Prius II - all perfectly works
Discussion in 'Gen 2 Prius Technical Discussion' started by Prius_Russia, Mar 13, 2007.
  1. Prius_Russia
    Prius_Russia New Member
    Has installed Cruise-control Prius II - all perfectly works
    Installation is similar Prius Classic - necessary spare parts:
    -The switch
    -Cable
    -The brake sensor (with additional 2 contacts for cruise)
  2. tochatihu
    tochatihu Senior Member
    9,697
    3,742
    Kunming Yunnan China
    2001 Prius
    Поздравляю!
    (from a Russian phrase book)
    You may need to confirm that the brake light switch is set so that it will power those lights (and cancel cruise) with only a slight push of the brake pedal.
  3. Prius_Russia
    <div class='quotetop'>QUOTE(tochatihu @ Mar 13 2007, 10:28 AM) [snapback]404834[/snapback]</div>
    Спасибо !!!!!!
    From me :blink:
    <div class='quotetop'>QUOTE(Prius_Russia @ Mar 13 2007, 01:01 PM) [snapback]404925[/snapback]</div>
    You may need to confirm that the brake light switch is set so that it will power those lights (and cancel cruise) with only a slight push of the brake pedal. - ALL WORKING SO GOOD !!!!
  4. Tideland Prius
    16,531
    cnobwars from me cause I have no idea what was just said :p:p:p
    I'm assuming cruise isn't offered in Russia?
  5. Prius_Russia
    <div class='quotetop'>QUOTE(Tideland Prius @ Mar 14 2007, 01:42 AM) [snapback]405231[/snapback]</div>
    Yes - cruise is factory option in Europe !!!!
  6. tochatihu
    9,697
    3,742
    2001 Prius
  7. Tideland Prius
    16,531
    <div class='quotetop'>QUOTE(Prius_Russia @ Mar 14 2007, 01:23 AM) [snapback]405256[/snapback]</div>
    Ohh.. so you're just adding the factory option then? I see.
  8. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    In Soviet Russia, car cruise you!
    [With apologies to "Family Guy", episode "There's something about Pauly".]
  9. Ramanjit81
    39
    Dublin, Ireland
    Thanks for the extensive and detailed instructions.
