Has running out of gas killed my hybrid battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wideslider, May 6, 2014.
  1. wideslider
    wideslider New Member
    Sydney, Australia
    Hi guys,
    I ran my Prius out of fuel and limped off the road. I put about a gallon of fuel in it and managed to get it to a service station to put a tank of fuel in. It drove like normal for about 1 mile and then the ICE started stuttering as if it was running on 2 cylinders. I parked the car and left it for the night. I went back to the car in the morning and tried to start it again. The ICE would start as normal, run for about 15 seconds and then turn off with all warning lights on the dash. The battery display is saying it has only 1 line of battery left. I used a scan tool on it today and it is displaying P0A80 (replace hybrid battery).
    Can anybody confirm that this is a likely thing to occur as I don't want to replace the battery if there is an easier fix.
    Thanks in advance!
  2. Rich12
    Rich12 Member
    176
    29
    Yeppers...you're done. Good job. ;)
    51,155
    it's unusual, but the battery may have been weak to begin with. how many miles on her?
  4. wideslider
    Sydney, Australia
    agghhhh.... She has 170 miles on her. She was going strong but I guess I have killed her. Should I buy a second hand low kay battery or a reconditioned unit?
  5. fuzzy1
    10,335
    Before being convinced that it has been killed, get a few more opinions first. The folks I'd trust on this have not yet weighed in.
  6. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    The design logic problem with Gen2, when you run out of gas, the car keeps going on HV battery power. If you discharge the HV battery too low, well, that's the problem. Gen3 I think they fixed this...the car will stop before the HV battery is discharged when out of gas. By all means get the experts opinion but, maybe you ran the battery charge too low.
    Here's cool web page of Dorman battery installers, if needed:
    Dorman Hybrid Drive Batteries - Installers
  7. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Have it scanned and checked professionally. I doubt that running it out of fuel would have killed it. Your nearing the end of the batteries service life, sounds more like a coincidence to me.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Running out of fuel can kill a marginal battery. Basically you took a few thousand miles off the life of the pack, which means what was maybe barely working can now be not working.
    As to "running for 15seconds then shutting off" that sounds very much like no fuel is getting pumped in because remember MG1 spins the engine off of the battery pack. And it gives up and lights up like a christmas tree around that point.
    How many gallons did you put in? A "tank" for some means whatever spare change they have instead of fulling up to the top.
    If it can't spin fast enough to start it up because your pack is too low, then the gas engine will never start and you have a chicken and egg problem. This is why 1 bar under normal circumstances is 40%. It can start the engine down to about 18% or so. But you can run in EV only when out of gas to that level, well below the safe 40%. Then every subsequent start you lost a little bit of SOC.
    Do you have a scanguage or other CAN reader?
    WNY-HYBRID likes this.
  9. Patrick Wong
    18,200
    6,493
    Do you mean 170K miles on the odometer?
    I suggest that you disconnect the 12V battery for a few minutes, then reconnect and make the Prius READY. See if the driveability symptoms persist. If yes, read the DTC again and if you still get P0A80 then you'll have to figure out how you want to replace the traction battery.
    I personally would try to buy a used 3G traction battery and move the 28 modules into the 2G traction battery case.
    dorunron likes this.
  10. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I learn a lot from this forum. Great informed answer.
  11. wideslider
    Sydney, Australia
    I used a scan tool which gave the P0a80 code. I cleared it and it started the ICE but just runs for a short period of time then shuts down. I can't understand the logic as to why the ICE shuts down and doesn't try to charge the battery. The car won't let me select drive or reverse and it has a full tank of fuel.
  12. Patrick Wong
    18,200
    6,493
    Try to make the Prius READY again. When you hear the gasoline engine spin up, then depress the accelerator pedal and see if the engine will increase its speed.
    If the engine will not increase its speed, then you will know that it is not actually running. Rather MG1 is spinning the engine in an attempt to start it.
    After a while, when the engine does not start, the hybrid vehicle ECU will stop MG1 to avoid draining the traction battery excessively.
  13. wideslider
    Sydney, Australia
    Interesting. Does this mean I may have an issue in the ICE?
  14. Patrick Wong
    18,200
    6,493
    Assuming the gasoline engine does not actually start, read the DTC again and see what is logged. If there are codes other than P0A80, then post and we can discuss what to do about them.
  15. wideslider
    Sydney, Australia
    I'll go check again and see if I get any other error codes.
  16. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    I'm surprised no-one has stated the obvious. Why don't you take (tow) the car to your dealer and have them charge up the HV battery before declaring the HV to be dead?
    Just my 2c worth.
  17. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    doj,
    There are some dealers that will not charge up the high voltage oack.
    Instead they will simply sell you a new one, since you have a P0A80 "replace hybrid battery" code showing.
    wideslider,
    It's unlikely your battery is completely dead. But it is likely that you drove the voltage down too low for the car to start. And the more times you try to start it, the worse things will get.
    After Memorial Day, I could sell you a charger that you can install yourself that would charge up the pack.
    (The chargers are still finishing being tested/made ready for sale.) My guess is that you don't want to wait that long.
    Where are you located? If you are near me, I can do an emergency charge of your pack.
  18. dolj
    dolj Senior Member
    8,217
    4,187
    Best avoid these charlatans, IMO.
    I thought it was SOP to recharge the pack in this (ran out of gas, ran the HV low/flat) scenario.
  19. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    You would think so, but I had a customer who offered to pay them for this service and the dealer outright refused to do it.
    Apparently the dealer does not have a high voltage pack charger on site and needs to get it from some central location. Maybe they thought it was too much of a hassle?
  20. dolj
    dolj Senior Member
    8,217
    4,187
    Sadly it seems that customer service is disappearing, in favor of big bucks.
