Has this question been answered...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by C56spd, Nov 21, 2011.
  1. C56spd
    C56spd New Member
    32
    Green Bay, Wi
    Just wondered if having your Prius plugged in and charging (or charge complete) will disable you being able to start or move your car.
    I would imagine this has been thought of as a safety feature. Still, I keep having this picture of my wife backing out of our garage with the charger still attached!:eek:
    Tell me this can't happen!!!
  2. Tideland Prius
    16,127
    I believe the car won't start until it's unplugged but it's a strong educated guess until Toyota says so. It's been six months.
  3. minori
    minori New Member
    Nissan Leaf won't start while it is charging. I guess Toyota will be the same.
  4. Cutlass
    Cutlass New Member
    17
    New England
    As per the J1772 standard, the car is not allowed to go into drive if the charging connector is connected to the car. There's a "proximity detection" setup (hall effect, etc) that detects if the charger is connected to the vehicle. Note, it does not matter if the J1772 connector even has a wire going to it, the car is not allowed to go into drive.
    There is also a "networking-like protocol" between the charger and the vehicle. If a proper connection isn't determined, then the charger will not energize the contacts and the vehicle will not allow any charging of the batteries.
    Someone asked what happens if the car is in motion (slowly) and the connector is attached. From what I remember of the standard, there's no "requirement" for a specific action. It is very possible to have the car moving at 1 mph and have someone walking along and plug in the connector. It would not be a smart thing to try since it could easily damage the connector on the car - and that would be very expensive to fix! :)
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    It will not allow it and a messasge comes across the MID display as well.
