Hatch back ground
Discussion in 'Gen 2 Prius Technical Discussion' started by KD6UNR, Aug 18, 2014.
  1. KD6UNR
    KD6UNR New Member
    Bellflower, Ca
    Is the 2008 Toyota Prius hatch back grounded to the chassis?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I'm sure it is, if not by a grounding strap, then definitely through the steel hinges.
    Very easy to test with a multimeter.
    SCH-I535
  3. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    While the hatch is grounded by the hinges be careful as the hatch is aluminium and is difficult to make a good permanent connection to.
    John (Britprius)
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I bet the black wire is ground on the wiper motor
  5. Britprius
    5,194
    1,914
    The problem is from a radio point of view the accessory wiring in the Prius is so thin this would not be considered a good ground. Using the wiper motor ground would introduce interference into the ariel path since not explained in this thread although it is in a duplicate thread it is for an amateur radio Ariel.
    John (Britprius)
    #5 Britprius, Aug 18, 2014
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The hatch itself is thin. At that point only the hinges have any hope of being thick enough.
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    its not good for the hinges to run current through em anyway. that's why the wiper motor has a ground wire. hinges need to be lubed; oil or grease isn't conductive. gonna have to run a thicker ground wire to the stud where the battery - wire hooks to the body. what gauge ground wire do you need?
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    There is a ground wire that runs from the hatch, through the rubber grommet to the ground block on the driver side rear wheel hump.
