Hatch Lift appears to have broken - what next?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nottenst, Nov 17, 2012.
  1. nottenst
    nottenst Junior Member
    Bowie, Maryland
    I was opening the back hatch and it seems that one or two of the plastic connectors that keep [the handle] fastened onto the hatch broke on the right hand side. I went to the dealer and asked about it and they said that I would need to replace the whole thing. The part is a garnish sub-assembly and the part cost they had was $229.17. (part #76801-47060-J1)
    This seems a really bad design that this little piece of plastic breaking results in needing to replace this $200+ part. I did see online some places selling it for about $150. Has anyone replaced one of these? How difficult is it? Thanks.
    49,507
    not sure what you mean, can you take a pic? the plastic connector that keeps the hatch attached to the hatch?
  3. nottenst
    Bowie, Maryland
    Here is a photo of the hatch handle pulled out. You can see the broken plastic on the right.[​IMG]
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I think I've seen breakages on Gen 2 Prius taxis running around.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I would check out a local auto body place and see if they can help you out. They may have that little connector sitting around and do it for free or just a few bucks. Stuff like that, at the dealer, is asking to be burned.
  6. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
  7. bisco
    49,507
    how about from a junk yard?
  8. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    I had a broken clip, I ended up replacing both oem struts with new ones from autozone. About $138. New struts work well, old ones were getting weak. I use the hatch a lot - shopping, loading, unloading dogs, camp gear, etc. So, for 4 years of constant use, I am not surprised old struts were wearing out.
    DBCassidy
