Hatch light
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Subversive, May 18, 2006.
  1. Subversive
    Subversive New Member
    251
    It seems to me that there should be a light that shines down on the hatch area whenever the hatch door gets opened. Perhaps this light could also give an early clue when the hatch door is not shut all of the way too. Has anyone added such a thing?
    EDIT--Or maybe there is one, and it's shut off. I haven't got around to reading the manual yet, or doing a thorough daytime visual inspection. :p
  2. benighted
    benighted New Member
    530
    Westport, WA
    You could probably run a wire from the current hatch light to a custom one.
  3. darelldd
    6,057
    389
    Northern CA
    There IS a light in the cargo area that can be switched off... and is normally switched by the hatch. Look in the cargo area, it is low on your left. Is this what you are looking for? If you put a light up on the hatch to shine down, then you'd make a big shadow when you leaned in to get something.
  4. Tideland Prius
    16,158
    It's on the left side, isn't it?
  5. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Tideland Prius @ May 17 2006, 11:32 PM) [snapback]257378[/snapback]</div>
    Oops. Edited. Thanks!
    You know me... I like to climb in there and turn around first.
  6. Tideland Prius
    16,158
  7. aaf709
    3,862
    2022 Prius Prime
    And if it's not bright enough, I know Darell has tinkered with it and replaced the bulb with an LED.
  8. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(aaf709 @ May 18 2006, 04:02 PM) [snapback]257737[/snapback]</div>
    Yeah, that 5W bulb is not quite up to the task. My LED conversion puts out about twice the usable light for 1/4 the energy. Some folks have complained that it is a bit TOO bright. :)
  9. edselpdx
    edselpdx Member
    191
    Portland, OR
    Yeah...pretty wimpy light there and is it just me or do others "close" the hatch only to see that "open door" idiot light shining on the dash as they're halfway down the block?
  10. Tideland Prius
    16,158
    not really. You can tell by the sound it makes when you close it whether it's latched or not.
