Hatch not opening fully
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by steve gerson, Feb 10, 2010.
  1. steve gerson
    steve gerson New Member
    texas
    The rear hatch door on my 2004 Prius will not open fully on its own, as it did originally. I open the hatch anticipating that it will go on its own to the full open position, but instead it stops before the last foot or so.
    More than once I have reached in to get an item and when I move away, I bump my head on the not-fully-open hatch.
    I haven't been able to find any information on how to lubricate the hatch strut. Is that possible, or do I need to replace the hatch struts?
    Thanks.
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    The hatch struts are actually otherwise known as gas springs - they have compressed gas inside which provides the lifting force - as they get old, some of the gas escapes past the seals - you need to replace them when they don't have enough force to open the hatch all the way.
    Haven't been there yet on the Prius; been there done that on my 97 Ford Explorer (hood and hatch)
  3. ThePackage
    ThePackage New Member
    74
    The struts are available on line for less than $40 each (compared to over a $100 ea at the dealer). I don't have a source but do a search.
  4. FishHawk
    FishHawk New Member
    176
    Try a little WD40 on the shaft of the struts, it works for me. FishHawk
    badriane likes this.
  5. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    It might also help soften and swell the seals to prevent leakage. I used the same thing on my Alfa Romeo and it helped.
