Hatch Trunk Door Malfunction - 2005 Toyota Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jep4040, Sep 1, 2024 at 9:15 PM.
  1. jep4040
    jep4040 New Member
    usa
    Recently, my 2005 Toyota Prius hatch trunk door has been intermittently opening, but most times staying shut/locked. I checked 2 different key fobs, and they both work fine.
    I took a 10 second video of the problem, and it may be an electrical/mechanical issue? As you can see, the latch that is activated when I press the trunk button runs out of "juice" the more times I press it.
    How can i go about fixing this issue? Thanks guys!! Video below.
    [Video:
  2. Tombukt2
    Tombukt2 Senior Member
    9,692
    1,695
    Durham NC
    First off make sure you're 12 volt is actually 12 volts and working you'd be surprised. Then after that more than likely the motor you're activating itself just grab one out of another car
