Hatchback higher lift gas struts?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by priumium, Aug 30, 2025 at 6:57 AM.
  1. priumium
    priumium New Member
    31
    Sweden
    Upgrade
    I am apparently way too tall and have hit my head on the trunk top of my two Prius gen2 for years, so I am testing/buying 5-10cm longer struts for the trunk. 550mm/21.x inches is my first experiment.
    Naturally they cannot be to newton weak, but 400N ought to be enough me thinks?
    Any tips and/or pitfalls experienced are greatly appreciated!
    #1 priumium, Aug 30, 2025 at 6:57 AM
  2. Leadfoot J. McCoalroller
    7,956
    7,422
    Pennsylvania
    2018 Prius c
    Is there enough room (lengthwise) in the door jamb to hold a longer strut when it is closed?
    strikes me that you'd have to re-mount the door-side ball anchors. Looking forward to hearing about it though.
    priumium likes this.
  3. Paul Gregory
    Paul Gregory Senior Member
    1,841
    453
    Alberta
    2024 Prius Prime
    XSE
    I believe you can order gas struts online, bespoke to stroke, lifting force etc.
    Gas spring 14-28 Stroke 500 Long - Gasspring.ca
  4. priumium
    priumium New Member
    31
    Sweden
    Upgrade
    Cheers, I have now ordered two 550mm from Frankberg with 400N lift force and the compressed length fit, it seems based on measurement between upper joint and lower mount rubber socket.
    Its only 5 more cm extended, but will report back.
    In the meantime, I watch this fellow who has bought 21inch and shared it (thanks to content provider and the old-school internet; 87 views! :))
    #4 priumium, Aug 31, 2025 at 6:38 AM
