Hatchback vs Garage Door (battle continues)
Discussion in 'Gen 4 Prius Accessories and Modifications' started by auguise, Sep 14, 2016.
  1. auguise
    auguise Junior Member
    Four Touring
    I bought a 2016 Prius Touring 4 recently and come across the same problem as many have posted on the gen 2 and gen 3. The hatchback when open is very tall and hits the garage door.
    I've seen another post where they were able to replace the lift support struts and lower the height of the hatchback. Has anyone attempted this on the gen 4 Prius?
    If not, I'd appreciate any help people can give in finding the appropriate strut to replace the stock struts. I haven't been able to find the right one on the internet yet.
    Here's the info I've gathered so far on what's currently on the Prius
    Stabilus 7R
    Lift-O-Mat
    221338 0540N 324/15 A31
    Toyota Part #
    68950-0W860
    Diameter of:
    Shaft 8mm
    Tube 19mm
    Force: 540 N
    Current length: 446.5mm (as measured from center of connector to center of connector)
    I want to reduce the length by 40mm
    Thanks in advance to anyone that can help
    RCO likes this.
  2. Mendel Leisk
    41,861
    One easy thing you can do: cushion the part on the garage door that's hitting, it'll reduce or stop scratching.
    I've done the deed about 4 times, never the wife, always me. :oops:
    Cushioning helps, but the garage door typically derails, lol.
    Here's what I've done:
    bisco and RCO like this.
  3. auguise
    Four Touring
    I tried cushioning. But I still need to be careful, the contact point could be the hinges. The solution works for me, but doesn't work for my kids who wouldn't be so careful when opening the hatch.
    dustinsmith129 likes this.
  4. Mendel Leisk
    41,861
    Yeah our garage has a 10' ceiling, luckily. The only thing that hits is the trailing arm. Understand your situation now.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Wasn't there a thread where someone put a cord on, tied to each end of the strut mountings to limit the extension ?
  6. auguise
    Four Touring
    I did that too but wife found it ugly. So it's only temporary. I taped sections of the cord so it would fold nicely and keep in place.
    RCO likes this.
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Dang. Another wife spoils our perfect plans! :LOL: Looks like it works for you.
    RCO and marcpablo like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    That's the idea, black cord would be less visible. I was thinking of something along the lines of a single cord (one on each side of the hatch) with loops on the ends, hooked over the little ball joints that the struts fit on to.
    RCO likes this.
  9. auguise
    Four Touring
    I ended up buying 1/8" black bungee/para cord off of Amazon.
    Made a loop and kept tying it smaller till I got the limit I wanted. The loop is better so I can take it off easily if I want the full extension on the door.
    Put one on each strut.
    Seems to work and barely can see it
    kithmo, RCO and bisco like this.
  10. bisco
    52,350
    ingenius!(y)
  11. Colorblind
    Colorblind Junior Member
    michigan
    Three Touring
    Just back in instead.
    kithmo, MrMischief and krmcg like this.
  12. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    Here we have the real solution. It's safer, easier to load, and makes for faster getaways. If anyone gives you grief about it, just ask "Does batman ever back out from the bat cave?"
    kithmo and RCO like this.
  13. Mendel Leisk
    41,861
    ^ That would actually work champion for us, except I'm pretty challenged, backing into spots, lol. Maybe something I should try.
    MrMischief and RCO like this.
  14. WastedTheLight
    WastedTheLight Junior Member
    16
    Bloomfield Hills, Mi
    My hatch hits my door too. I have a couple of scratches on it now, many foul words have been said. I'm hoping adding a backup camera last weekend will help me to start backing in now.
    RCO likes this.
  15. bisco
    52,350
    why is it easier to back out than back in? going out, there's no target. much easier. same with a parking space.
    RCO and Mendel Leisk like this.
  16. Mendel Leisk
    41,861
    Yeah, and maybe innate: nobody likes backing into a black, forbidding hole...
  17. bisco
    52,350
    i had to delete what i was going to post.:oops:
    MrMischief, kithmo and RCO like this.
  18. Mendel Leisk
    41,861
    great minds...
  19. bisco
    52,350
    i was afraid Chris or Michelle might come along. :whistle:
    RCO and Coast Cruiser like this.
  20. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    Keep tether cord. New wife. Issue resolved.
