Hatchback won't open
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Donova, Oct 30, 2013.
  1. Donova
    Donova New Member
    Help;
    I closed my hatchback in the dark and caught the cargo net in the hatch when I closed it. I tried unlocking with the remote and then with the door lock when the car was turned off. All to no avail. The hatchback will not budge but looks to be open a little. Any ideas on how to open the hatch???
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    This will open er up. ;)
    Seriously, you might have to sacrifice your cargo net by carefully cutting it around the hatch locking area and pulling out the pieces so the locking mechanism can disengage.
    SCH-I535
    macman408 and spiderman like this.
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    Isn't there a manual override pull cord for opening the hatch? I think it's buried behind a small rectangular access panel but you have to take out the lower tray to see it. All of this must be done by crawling back there from the rear seat area.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    you might be able to just push down while pressing the button and then lifting up...
