Hate Exxon Mobil because of Valdez so...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Doug, Feb 28, 2010.
  1. Doug
    Doug Junior Member
    33
    Indiana
    2013 Prius Plug-in
    I know Mobil 1 synthetic is a good oil but what is the best oil that Exxon Mobil does not make?
  2. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    You're going to get a lot of opinions! I've been very impressed with the used oil analysis results I get using Amsoil. But it's only worth it if you go for extended use, I find that I can safely double the recommended mileage in both my cars. Many people say that Mobil 1 Synthetic gives the same results for less $$, but since you want to avoid them...
    - D
  3. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Shell's Full Synthetic is much cheaper than Mobile. Not sure if there is difference in quality.
  5. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Castrol Syntec is popular with the racers. I have used it in turbocharged cars (where the turbo cooks the oil and a synthetic should be a must). It is often cheaper than Mobil 1.
  6. nthach
    nthach New Member
    174
    For mass-market oils I like Pennzoil Platinum and Valvoline SynPower for synthetics. For dino you can't go wrong with Valvoline white bottle/MaxLife, Pennzoil yellow bottle/High Mileage, Castrol GTX or Chevron Supreme/Havoline.
    If you desire something a little more exotic, Red Line. Bottled locally in the Bay Area :)
    I prefer synthetics in Toyotas if you use the maintenance light for OCIs. If it was a Honda or GM, I have no problem with dino as they tend to be gentle on their oil.
