Hating the JBL Stereo in 08
Discussion in 'Gen 2 Prius Audio and Electronics' started by Lveh8lve, Jul 22, 2008.
  1. Lveh8lve
    Lveh8lve New Member
    Dutchess County, NY
    I'm driving home from work today and a good song comes on my sirius (currently set up through an FM transmitter as the AUX input has massive feedback and i haven't had time to get the sirius hardwired).
    So like anyone else I turn the radio up. It's not loud, I turn it up more. It's not getting louder. I look down and it's at MAX. I can't believe it. I have never had a car or a stereo where I hit the max audio and wasnt satisfied.
    I'm really regretting paying extra money for this garbage stereo. It sounds like crap all the time and the AUX is nothing but feedback on whatever I plug in it. Has anyone modded the car to put a somewhat decent system in? I was wondering how that would act with the hybrid system (not to mention my bank account :( )
  2. kazots
    kazots LifesaBeach
    262
    CALIFORNIA
    I'm not that crazy about my radio either. JBL speakers so what!
  3. doubleg2005
    doubleg2005 Member
    236
    max? i've NEVER maxed out my audio... i've turned it up as high as 50 for a podcast that was recorded pretty low volume, but it's plenty loud around 30...
    just curious, what is max?
  4. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    Playing a satellite radio through an FM transmitter may be the problem. Once you get it hardwired you may be a lot happier.
  5. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    A lot of Chatters think the JBL Stereo sounds better with the center speaker disconnected (do a search for threads on this topic).
    The feedback issue with the AUX input is fixable. Get your dealer to fix it under the warranty (do a search for a recent thread on the subject).
  6. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    The JBL system is pretty good. Not the best, but I'm satisfied with just a bit of tuning. With regards to the FM transmitter, they broadcast typically at a pretty low volume. I'd find a better solution for hooking the sat radio up. An FM transmitter with high volumes is lame to begin with.
    The stereo goes up to 63, 64 is max. I have a few songs that I'll listen to on max because the mp3 was recorded low. Normal level recordings are sufficient on this system. yea, it's not nearly as loud as other stock systems, (my mygig in my '08 grand cherokee blows the jbl system out of the water) but it's pretty good for a relatively inexpensive car (my grand cherokee srt8 was over $50k out the door).
  7. rjparker
    rjparker Tu Humilde Sirviente
    7,601
    4,458
    Texas Hill Country
    My older XM portable has a setup option for more gain to the fm transmitter portion. I maxed it out for better results with my Tundra. The FCC has been cracking down on "low power" FM transmitters, particularly those built into satellite radio systems. This is because x rated "shock jocks" have often been heard in adjacent cars on their way to Sunday morning church (or equivalent).
    Bottom line, get it hard wired into the JBL, ideally with a receiver made for the Prius so that you get control on the car's display unit.
  8. Lveh8lve
    Lveh8lve New Member
    Dutchess County, NY
    I am just looking for time to take it in and get it hard wired. I have the ToySC1, just no time to drop the car off.
    I've had my car for about 2 weeks now, you think they would have factory shipped it out with the TSB already done!!!!
    I'm just really dissapointed about the quality of the stereo in general. My old old Suxsuzu "Side of Road" - eo (My pet name for my old Isuzu Rodeo) had a better stock system in it. If your gonna tag a name such as "jbl" on it and charge extra money it should at least sound decent. Especially since I am very hesitant to upgrade anything aftermarket and screw with the hybrid system.
    If toyota was on the mark and really wants to market this car to the twenty-something techno gadget crowds this stereo needs to go in the dumpster.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    This is a source volume problem, not a problem with the JBL. We see this when we connect an mp3 player through the AUX input and find we need a higher volume setting to compensate for the lower input volume. The same thing is happening with your FM modulator. Crank that up and you will have plenty of volume, or better yet fix your ground loop problem on the AUX input.
    Tom
  10. steveholtam
    steveholtam Junior Member
    44
    Sacramento, CA
    Most, if not all portable satellite external units have a built in volume controls. Increase yours so that is outputting louder.
  11. JamesWyatt
    JamesWyatt Señior Member
    348
    Allen, TX
    Turn down the volume. You're going to give yourself permanent hearing damage. :)
  12. brick
    brick Active Member
    1,083
    78
    Upstate NY
    If you don't have time/don't want to go to the dealer for the ground loop isolator, just get one from crutchfield. They're cheap and the improved audio is well worth it.
    That, and what JamesWyatt said.
  13. TheDrGene
    TheDrGene Beard and Sandals Group
    Lompoc CA
    (I just finished installing the KSC sw-10 subwoofer. I am amazed at how well it filled the sound from the system. I had previously installed Boston Acoustic Pro60 component speakers and there was only a little improvement over the JBL system. The subwoofer made a much bigger difference. (besides, it was a complete pain to try and find a place to put the crossovers!)
  14. PriusChick1
    PriusChick1 New Member
    27
    California Beach
    Hi qbee42
    THis is the first time i've read this. I've gone thru so many posts to try to find a simplified answer and "fix"the JBL system.
    i 'm thinking of adding a powered subwoofer and replacing speakers.
    how do i set the needed source volume exactly? if this will create a much better listening experience i may not have to replace the door speakers.
    thanks ! :cheer2:
  15. fo0bar
    fo0bar Junior Member
    66
    Reno, NV
    I listen to NPR with the volume anywhere between 10 and 25, depending on if I'm parked or driving. Damn kids...
    (OK, I'm 27.)
  16. Silver 2008
    Silver 2008 Junior Member
    71
    Idaho
    I think the JBL system sucks as well. I have had many stereos, including custom competition grade, so I know a good stereo when I hear it.
    I have a Maxima with a BOSE. That car has the nicest stock system I have ever heard. It has a single 8" woofer in the rear deck. Very full, balanced sound.
    I also have a Chevy Silverado with a BOSE. Compared to the Maxima, the BOSE in the truck sucks. But the trucks system is waaaay better than the JBL system in the Prius.
    I had higher expectations from the uplevel JBL. I think it sounds tinny and cheap.
    Mike
  17. Stefx
    Stefx Member
    336
    Sirius/XM sound quality is by nature poor to start with. No radio is going to make Sirius/XM sound good. It's about equivalent to a 36kbps MP3. I consider 128kbps MP3s to be tolerable at best.
    That being said, the JBL sound system is ok when playing CDs. Not bad and not very good either.
  18. fo0bar
    66
    Reno, NV
    Uhh, no. XM uses AACplus with a variable per-stream bitrate. Last time I checked, most music channels are at 48kbps AACplus, which is roughly equivalent to 128kbps MP3 stream. Non-music channels are lower, with news/sports channels usually at 16kbps (42kbps MP3 equivalent, somewhere between AM and FM quality), and channels like comedy at 24kbps (64kbps MP3 equivalent, roughly FM quality).
    Sirius uses the PAC codec, which I don't have hard numbers on, but it's roughly equivalent to XM (though XM/Sirius fanboys will fight over this).
    Assuming you're not flat-out trolling, you may be thinking of the companies' internet feeds, which used to be bad (48kbps MP3 for XM, 32kbps MP3 for Sirius), but both companies have been doing their internet feeds at 128kbps for a long time now.
  19. Stefx
    Stefx Member
    336
    Foobar, thanks for clarifying the actual rate vs codec phenomena.
    Your explanation made me search on the internet to understand this better. I then looked for sound quality reviews (48kbps AAC+ vs 128kbps mp3)... it's an obvious subjective comparison by nature of course, and I observed a mix of opinions in regards to the 48kbps AAC+ vs 128kbps mp3s comparison. Some claim it's equal, some claim it's not.
    That being said, if I play a 128kbps mp3 on my home system, it's tolerable at low-medium levels, but if the volume is cranked higher, the shortcomings are amplified and ruins the listening experience.
