Have question about 05 factory radio
Discussion in 'Gen 2 Prius Audio and Electronics' started by edw91901*, Sep 12, 2020.
  1. edw91901*
    edw91901* New Member
    28
    paint rock,AL 35764
    My Prius came with a jbl am/fm radio with cassette player i put a 06 Prius am/fm single CD player non jbl is there a way to make the jbl system to work
  2. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Not in any way that would be a sensible use of time or money.
  3. edw91901*
    28
    paint rock,AL 35764
    when i bought the car it had a kenmore radio in it but instead of using adapters he cut all the wire harness keep what was need to make radio work it shorted out from a necked wire but i redid everything back to factory just having a problem find a jbl radio put back in it
    #3 edw91901*, Sep 12, 2020
  4. dolj
    dolj Senior Member
    8,557
    4,348
    Wellington, New Zealand
    If you search the Gen 2 forums (either this one or the "Gen 2 Prius Accessories & Modifications" forum*), another member detailed how you can use other models. Personally, I'd keep looking, one is bound to turn up with the part number you need.
    * Use the advanced search (click the "More..." button) to limit the search to the forum you want and more.
  5. edw91901*
    28
    paint rock,AL 35764
    i found the factory radio that gose in it but need the pinout on the connectors on the radio it the 86120-47100 toyota 56838 jbl with casett player 6 disc cd ive look every were and cant find one
  6. Elektroingenieur
    2,515
    3,287
    Three Touring
    See the Electrical Wiring Diagram (more info) for the 2005 Prius, EWD599U; you need the pages for “Multi-Display and Audio System with Separate Amplifier” and “Connector List.”
