Have you ever pumped more than 10 gallons of gas?
Discussion in 'Gen 2 Prius Main Forum' started by Vespasian, Mar 8, 2006.
  1. Vespasian
    Vespasian New Member
    126
    Illinois
    I've actually never been able to pump more than about 8 gallons of gasoline at one time, even when the fuel gauge shows only one bar remaining.
  2. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    I drive until the last bar 'blinks' and then for maybe 10-15 more miles. I seem to be able to fill 8 gallons evey time I fill up. I wish I could nake use of more like 10 gallons as 80-100 miles would be several more days of driving
  3. 2Hybrids
    2Hybrids New Member
    565
    Eustis, Florida
    temperature makes a big diff.
    The most I've ever been able to safely pump is 8.7 gallons....at one pip.
  4. aaf709
    3,862
    2022 Prius Prime
    A little over 9 gallons once or twice. Normally between 8 & 9 gallons.
  5. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    9.7 once. Usually between 8-9.
  6. astro
    astro New Member
    this drives me nuts. i too average 7.5 to 8.5 gal per fillup. what happened to the 12 gal tank? i can understand a gallon or two, but not being able to use a full 1/3 of the tank?
  7. Vespasian
    126
    Illinois
    When it's cold outside the bladder in the tank apparently gets very restrictive.
  8. Kestrel
    Kestrel Bird geek
    59
    SF Bay Area, CA
    My max so far has been 9.959, with most of them in the 8.5 to 9.5 range. I usually let it get down to two pips; once I waited until I was on the last pip; and just once I got to blinking!
    [Edited to add] I stop at the first click of the gas pump.
  9. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    I give up on trying to figure out how to fill it. Put in 9.4 once when I got to blinking pip but otherwise 6-8. I'll click it once or twice but I am not spending much time at the pump.
  10. the fish
    the fish Member
    175
    On my first tank, I was able to squeeze in 10.003 gallons. I was down to one bar (no blinking yet) for about 10 miles. It was around 63 degrees. I'll see how the second tank goes.
  11. daronspicher
    daronspicher Active Member
    1,208
    After it clicks off...
    Back the nozzle out about 1 inch... gently add 1 gallon and stop.
    If you add 1.4 gallons at this point, you'll burp gas out the hole.
    Most people around here will cringe to hear me say that (and they probably should).. because it may do something or the other to some vapor filter or whatever. And, you don't want to be trying to save gas but then spilling it on the ground while trying to over-fill the car.
    Let it click off.. back the nozzle out a bit, then add 1 gallon.. don't wait until you see something happening at the fill spout.. it's too late by then. it clicks off at 8.9 gallons, go to 9.9 and stop.
    All that.. only if you want that extra gallon. For many people, they are just fine if they stop when it clicks off.
  12. the fish
    the fish Member
    175
    My 10 gallon tank did first click off at 8.8 gallons. I got to 10 by doing exactly what daronspicher posted.
  13. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I use daronspitcher's method also. Just .4 more than 1 gallon will make it bubble and spit out.
  14. redbird
    redbird New Member
    Still in Ohio, but hopefully not after retirement.
    On my first trip to Texas from Ohio - I ran the car as far as I felt safe - the gauge started blinking and I drove an additional 20 miles for gas - I was able to put 10.53 gallons in. I don't run it that close any more. (Note: My wife was driving our old Camry behind me - we dropped it off for our daughter in law) - so I wasn't gambling too much. But I only got 40 miles per gallon - we were traveling 70-80 mph - with the rest of the traffic.
  15. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    I normally drive til the warning comes on and look for a station. On GreenHybrid I post my history and it runs from 9.3 to 10.3 normally. Purchased '05 in Nov '05, I believe that makes a difference. From the original Gen2's in '03/'04 to the present there was a flow sensor adjustment.
  16. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    Am I tempting fate?
    Five months and 8100 miles after buying the car I've refueled it about 15 times, ALWAYS when the last pip has been blinking for the past 10 miles or so. ALWAYS put in about 10.5 gallons and grumble that there's a gallon and a half I apparently can't use (1.5 + 10.5 = 12).
    Exception - one station a few fillups ago had a faulty nozzle cutoff, so as I stood behind the car studying Nick Park's latest Chevron cartoon suddenly heard the sound of a waterfall and turned to find the pump merrily pouring fuel all over the pavement at full force, geysering out of the filler! Got it stoppped with 12.6 gallons on the pump meter - have no idea how much of that 12.6 was puddle on the pavement but assume it wasn't more than a gallon. That would mean I managed to cram in 11.6 or so with the help of that unregulated pump. Topped 550 miles on that tankload before the last pip started flashing, so I obviously got more fuel into the tank than I normally do, but I don't have any idea of what that 11.9 gallon bladder really can hold or what's it's true useful capacity is.
    But so far I haven't run the thing dry and have gotten at least 20 miles on the flashing pip.
    Anyone run dry with less than 20 on the blink?
    Mark Baird
    Alameda CA
  17. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Before EL010-04 I would get in 6.5 gallons at one bar.
    Now I get in 8 gallons at one bar.
  18. micheal
    micheal I feel pretty, oh so pretty.
    842
    Lubbock, TX
    Yeap, we ran out of gas once on a road trip. Went down to one bar as we passed a town with about 20 miles to the next town. Five miles after passing the town, the pip started flashing, about a mile later, the add fuel sign went on and the car started to slow down. We limped to a gas station and put in 11.728 gallons. Needless to say, when I am traveling on the highway/interstate and I am down to one bar, I make sure to fill as soon as possible.
    To answer the original question, in about 60 tanks, I have had 12 tanks over 10 gallons, with 3 of those 11.49 gallons or greater. (2004 Prius, Since September 2004).
  19. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    When I drive to the blinking bar, the car always takes at least 10 gallons.
    If I drive near empty I can get over 12 gallons in.
    All cases I fill to full. Sometimes I see the fuel, other times I stop based on the sound change, which is close to where I would see fuel.
    Car will fill full no problem but takes time. Car burping is caused by rushing and pressurizing the bladder. This can happen even when the car is not filled full. If you fill fast I've had it burp at the first click off.
    Generally I get at least 2 gallons and sometimes 3 more in after the first click off.
  20. Florida Prius
    Florida Prius New Member
    192
    Lake City, FL
    My two cents: i usually get right around 10 gallons, down to one bar on the gauge and hang up the nozzle after it clicks off. Usually is good for about 410 miles.
