Have you had any issues with aftermarket rims?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by priusenvious1, Dec 9, 2012.
  1. priusenvious1
    priusenvious1 Member
    325
    37
    LA
    In my experience, there's always been some headaches with getting aftermarket rims. They seem to tend to bend, especially driving here in LA. Most of them aren't forged and are weaker than the OEM rims. Just wondering how people are doing here over the long term with rims? A {rius tends to have somewhat smaller aftermarket rims than other vehicles (17's and 18's versus 19's and up) so maybe this is not as much of an issue?
  2. ockevin
    ockevin Active Member
    493
    148
    Orange County
    I have no problems with my rims. I have 18" and no bends. I look out for pot holes and dont go over them, but I have had bigger rims all my life and never bent or broke a rim.
  3. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I've never had any issues with any wheels on many different cars over the past 30+ years. Not sure what you are experiencing to be honest. You will increase the chance of damaging a wheel if you use a tire that has little to no sidewall.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    The only rim I ever had that got damaged is my OEM rim. Hit some debris on the freeway, blew out my tire and bent my rim.
  5. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Many people opt for the larger diameter wheels which drives the after market. Larger wheels = low profile tires. Some low profile tires look like no more than a rubber band on a wheel.[​IMG]They may look "cool", if you can tolerate the negatives. Google "low profile tire problems". Nuff said??
    Do you remember when a wheel was composed of a hub, spokes and rim? Now the whole thing is referred to as a "rim".
  6. priusenvious1
    325
    37
    LA
    Yes, it was european sty;e and it had a lip. I think anything with a lip is more likely to bend from what I understand.
  7. xliderider
    7,869
    3,116
    Honolulu, HI
    It really doesn't matter. The "lip" is just a matter of offset, how much the spokes are offset from the centerline of the wheel. Even if there isn't much offset, and there isn't much "lip" on the outside of the wheel, there will always be a much larger "lip" on the opposite side of the spokes toward the inside of the wheel. Therefore, the strongest wheel would have an offset of zero, which places the spokes directly in the centerline of the wheel.
  8. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    The Belle Tire store manager recommended that I put winter tires on my factory wheels as they stand up to winter slush and potholes better than most any aftermarket wheels. My only problems on the Prius is reliability of aftermarket TPM sensors.
  9. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    My second car with 40 series tires with 18s and never an issue. I would not go lower than a 40 series tire however...at least not for a daily driver. You have to take care...similar to the care needed if you lower the car.
  10. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    A friend who owns a tire store told me that the problem isn't so much with the rims bending after installation, but is that the rims wouldn't be "round" in the first place. And if they aren't round in the first place, there can be a weak spot on them, thus more susceptible to bending. But he also said that most aftermarket rims are pretty good these days as opposed to 10 years or more ago.
    Mike
  11. priusenvious1
    325
    37
    LA
    How about gas mileage? Has your car suffered from that going from a 15" to 18"?
  12. NineScorpions
    375
    64
    For sure you will lose mileage...the exact loss is dependent on the wheel and tire characteristics (size, weight, LRR, etc)
  13. NineScorpions
    375
    64
    Here is one data source for mpg with different sizes (keep in mind this is only one example of many variations and results. Also note that is 15s and 17s...
    SoCalBPrius's profile | Fuelly
    Look up user "F8L" here...he is pretty much the expert on these matters.
  14. priusenvious1
    325
    37
    LA
    Good info. Thanks. I also wonder the weight on my 15's...
  15. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    PIP wheels are 18.25lbs. The GenIII Prius OE 15s are 16.3lbs.
  16. priusenvious1
    325
    37
    LA
    Great info. Thanks!
  17. priusenvious1
    325
    37
    LA
  18. priusenvious1
    325
    37
    LA
  19. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
  20. priusenvious1
    325
    37
    LA
    Ah I read that wrong.. Yeah you're right. Oh well.
