have you noticed any MPG difference by lowering the oil level
Discussion in 'Gen 2 Prius Technical Discussion' started by WWJD08, Mar 18, 2009.
  1. WWJD08
    WWJD08 New Member
    70
    Frederick, Colorado
    By Lowering your oil level by 8 oz. Is it worth it and what did you notice by doing this? Pro's & CON's :cool:.
  2. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    When I change the oil - using the dealership filter - putting in 3 litres will put the level about halfway between the Add and Full dots. If I use 3.3 litres, that puts the oil level on the Full dot
    No difference in fuel economy that I can determine
    I'm now fairly convinced the "overfill" problems reported for the Prius, really have to do with how quickly the oil is put in. Eg say a dealership or Iffy Boob place with an automated bulk dispensing oil system
    Flood the cylinder head with motor oil, the excess can end up in the PVC vent or suction line, and be gulped into the intake. Take your time adding oil, I allow 10 mins to slowly add 3 litres
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    I honestly don't see how there would be a measurable difference in FE based upon where the oil level is between the two marks on the dipstick. Anywhere between the two marks is acceptable as shown in the owners manual. What you should avoid is overfilling the level; the level should not be above the top mark.
  4. triumph1
    triumph1 Member
    275
    I put in 4 quarts when I changed mine with no issues.
  5. Bob64
    1,540
    92
    Virginia
    check your oil level... you may have overfilled it....
  6. triumph1
    triumph1 Member
    275
    It was slightly over the fill mark, by about a fingernail. Has been in for about 8k, no problems, still getting 52+ mpg.
  7. bwilson4web
    15,372
    Near as I can tell, it is an issue of overfill. My experience is that 1/4 inch, about 5 mm is enough to have an impact. Right on the "F" seems OK and less than "F" and above "E" is perfectly OK. Under "E" has no effect other than to risk potential engine damage and wear out the remaining oil sooner.
  8. David Beale
    David Beale Senior Member
    5,963
    1,979
    Edmonton Alberta
    I used to put in 4 litres and now put in 3.5 litres. With 4 the oil ended up above the full line by about 3/16". I saw -NO- difference in mileage. I now put in 3.5 litres just to be able to say I'm "doing it right". I use the Toyota brand oil filter.
    I also put in one litre of 10W30 Mobil 1 and 2.5 litres of 5W30 Mobil 1. I'm still using up the anti-Prius' oil left over. This also made no difference in mileage.
    Some members of this forum need to "chill out". ;)
