Having problems starting my Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dman415, Jun 9, 2023.
  1. dman415
    dman415 Junior Member
    San Francisco
    For the last three months I'm increasingly having trouble starting my Prius. I continually get a message telling me to put the car into park before starting it, which I do, but then when I press the START button the PARK light on the dashboard automatically goes off and I get a dashboard message telling me to put it into Park and start again. It just continues. I'm now only able to start the car by pressing both the START button and the brake at the same time. I read in some forums that it could be a battery issue and had my 12v replaced with no change. Today I'm noticing that it's beginning to take several tries of pressing both the START and brake at the same time to be able to get the 'click' when I shift into Drive or Reverse... I also got the "Maintenance Required Soon" message, which concerned me but may just be coincidental with the usual 5,000 mile oil change suggestion. Has anyone encountered this issue or have any idea what night be causing it?
    51,154
    this is a fairly new car, any history? how many miles?
  3. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
  4. dman415
    San Francisco
    I currently have 72,000 miles on it , purchased certified at 32,000 miles from Toyota in 2018.
  5. bisco
    51,154
    could be rodente issue with chewed wiring. take a look at the engine and cabin air filtersfor signs of infestation.
    also, check the voltage at the jump point under the hood with the car off.
    make sure the brake lights come on before pressing the power button
  6. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_O
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    Sorry but I don't understand this.
    It is designed so that you must press and hold the brake BEFORE pushing the START button.
    Every time. Always.
    ColoradoBoo likes this.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,143
    749
    Monument, Colorado USA
    Sounds like an electrical gremlin....my worst fear when working on cars! The computer requires the brake peddle to be pressed before it will allow the car to start. Since you got some warning messages, I bet there's some codes you could pull up with a good scanner. If you don't have one, might be worth it to have a mechanic with one check it out. (It could be the ignition switch/button going bad) The car isn't old enough for ground problems, yet, unless you live in the rust belt, then I'd also check grounds.
  9. ASRDogman
    ASRDogman Senior Member
    7,241
    3,780
    The car won't "ready" unless you press the brake pedal, then press the start button.
    That is normal.
    Have you checked the 12v battery? Is it the original battery?
    EDIT: I just reread and see you had the battery replaced. Did you charge it?
    They do not charge them up at the stores. So put a 4amp or less charger on it for
    at least 6 hours, overnight is better. Then you KNOW it's fully charged.
    I'd bet that it's under 12.4 volts.... Just barely enough to fool you into thinking it
    is enough.
    When you do get it started, put the trip meter on "A". Shut the car off, then press the
    kph/mph button, press and hold the brake pedal and then the start button.
    #9 ASRDogman, Jun 12, 2023
