Having the Oddest Problems (2007)
Discussion in 'Gen 2 Prius Main Forum' started by FLPrius321, May 2, 2016.
  1. FLPrius321
    FLPrius321 New Member
    Melbourne Fl
    I have been expecting the check engine light to come on soon for routine maintenance, which I am taking into the shop on Wednesday. However, other things have started to pop up. The red triangle, (!), Check Engine, and VSC have lit up on the dash, but sometimes the VSC and (!) disappear.
    The battery has been charging and discharging fairly erratically. It will charge up to the green then be in the purple less than a minute later. Just now things got worse. It seems like the battery wasn't charging or discharging, as though its not even connected to the motor. Whenever I hit the pedal all I hear is the engine spool up with little to no acceleration. I have also started noticing a hissing noise, like a vent, on the passenger side backseat.
    Any ideas what this might be?
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Bad traction battery. "hissing" is the battery cooling fan running at full blast.
    Confirm by reading codes. Code reading options in my signature.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Hissing noise in the back along with fan running would be really bad.
    This can mean batteries are "venting" from too much internal pressure.
  4. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    It does sound like a HV battery. I rebuild them in my spare time. I'm set up to load test the modules and also cycle the pack multiple times before reinstalling to insure good balance. I currently have one ready to go. I'm located in central FL which isn't too far from you. $500 and I'll guarantee it for 6 months. I've done over 20 of them and the only come back I've had was on my mothers of all people.
  5. Former Member 68813
    3,524
    983
    US
    wow, this is great price. i assume refurbished with used modules?
  6. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    Yes sir. I buy used tested modules. I purchase about 5 at a time so I have a selection to choose from so I can get as close as possible to start with when rebuilding the pack.
