Hazard lights Won't shur off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hoz, Dec 17, 2012.
  1. hoz
    hoz New Member
    Hi-
    I have a 2010 Prius. I went out to my car, which was parked in a parking lot, and the hazard lights were blinking. I did not turn them on. I drove home for 20 minutes and could not get them to turn off the whole way. My car sits in my garage with the hazards flashing. Anyone have any advice? Thank you.
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    You have a short somewhere. Spill any water in the cabin?
    For now I'd pull the HAZ fuse, before it ruins your battery.
  3. 50324prius
    50324prius Junior Member
    39
    iowa
    you might also try lifting the plastic that surrounds the shifter and holds the hazard switch and then um plugging the hazard lights. I am not sure if it will cause the directional signals to stop working or not.
  4. Crockett3636
    Crockett3636 New Member
    New Hampshire
    Did you ever get this resolved
