Head Gasket Issues. Head Bolts?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by masterh, Apr 3, 2023.
  1. masterh
    masterh Junior Member
    17
    Los Angeles CA
    I saw someone saying prius c is safe from head gasket issues. I also saw someone talking about head bolt failure.
    I've been chasing engine rattle with coolant loss issues and I think it's head gasket.
    Check engine light came on and it indicated No 4 cylinder misfire. (tried switching the coil)
    Car works pretty nice during the day when it's pretty warm (Los Angeles)
    It does rattles here and there when I move the car after seating at the traffic light for more than 20 seconds. (meaning engine got cold and water seeped into the cylinder)
    So my question is, is replacing head bolts or tightening head bolts (Maybe tightening 5 pounds higher for bolts near Cylinder 4? or tight all bolts little higher?) might solve this issues since it's very small?
    I was going to do the valve cover gasket anyways. (saw oil on spark plug Threads)
    It looks like It sits underneath the camshaft.
    How hard is it to put it back? I am talking about aligning it correctly. Do I need a special tool?
  2. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Most engines with head gasket problems need hours to get cool enough to pull some coolant into the combustion chambers.
    If you can make yours rattle and misfire with a very brief stop like a traffic light, I'd be a lot more suspicious of the spark plugs than the head gasket.
    Be careful where you buy plugs. Lots of counterfeits sold online these days, particularly Amazon and eBay. Local stores are the best bet.
  3. Sonic_TH
    Sonic_TH Active Member
    545
    88
    Puerto Rico
    The coolant loss i think could be cause by the system the Prius C has, that the engine coolant circulates through the exhaust to warm the ICE faster, that can leak into the exhaust, give burnt coolant smell and cause coolant loss.
  4. masterh
    17
    Los Angeles CA
    Actually it can happen in 20 seconds (depending on the weather) I've watched mechanic explaining and people also replied with the same experience on youtube.
    When it was raining in LA, it was happening pretty much at every stop light.
    Now since the weather is a lot warmer, it only happens after car is parked for few minutes at night.
    Spark plugs are new from the dealer.
    I am refilling the coolant every week. I wish it was just from the exhaust like other person's said :(
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    Every car can blow a head gasket. The op's case is advanced.
  6. Sonic_TH
    545
    88
    Puerto Rico
    Has your Prius C ever overheated?
