Head Gasket Question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jdh2425, Feb 5, 2025.
  1. Jdh2425
    Jdh2425 Junior Member
    Baltimore
    I don't mean to start another head gasket thread, I know there are many threads and comments here already, but my question is a little different and I didn't want to sidetrack and current discussions.
    My 2010 Prius at 271k miles, started the engine shake at acceleration from idle and put up the #1 cylinder misfire code, with my coolant about 1/4 inch low. The car has been running perfect until now.
    Obviously it needs a head gasket and EGR cleaning. My local mechanic suggested getting a new car and gave me a ballpark estimate of around $3500, or more if it needs a new head, without looking at it.
    My issue is, I just put in a new Hybrid battery in October! Yeah looking back, that was probably a dumb decision. But I had always assumed oil burning would be the demise of this car, and since it doesn't burn a drop of oil, I figured the engine was good to go 400-500k. I also have the Prius Offroad lift with heavy duty springs and larger tires, so I don't want to junk the car.
    My question is, is there a preferred Maryland mechanic that does Prius head gasket jobs for a lower rate? I believe I can still drive the car to a location. Is it worth fixing? If not, could I even sell it with a bad head gasket?
    This all happened unexpectedly. I've always done my own oil changes and have always been amazed that it never burned any (I check it almost obsessively, always expecting the dreaded problem I read so much about), so I figured the car was worth putting money into, such as the batteries, shocks, lift, etc... and now this.
    PS. It's my only car, daily driver, so I'm forced to make a decision. I can't just "park it out back" until something comes up.
    Thanks for any suggestions!
  2. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    I was in this same situation with my 2013 luckily I had some generation twos that were just sitting here that I thought I would never drive It turns out the persona blew up and all of that nonsense similar to your engine here head gasket out shaking etc tried to fix it with a JDM engine ran great for about 4 months and then back to the shaking again I had tons of parts extra EGR valves intakes late model stuff that was all the new firmware none of it made any difference I had some of the lift kit stuff on one or two of mine too I can just take it off and slap it on another one and move that stuff over very quickly The market here in the southeast where cars are in nice shape or horrible for the generation 3 running or not it'd be tough to get 1350 for a solar roof car with the JBL stereo and pretty nice shape with a blown head gasket that's not been run since the gasket went out for the been no engine stretch nothing this was pulled off the road the minute we saw the signs of the coolant dropping It barely got a chance to shake and off the road it came. No one will touch it matter of fact I can't even sell the stereo out of it which is or was a desirable item the JBL 6 disc blah blah blah everybody wants to pay a hundred bucks for it it's in perfect condition no wear on the numbers or anything nothing so there's always that force these cars are hitting you know the 15-year mark now and stuff I think oh well so I just pulled the stuff off the Gen 3 that I wanted which is the blue tulip shift knob and the steering wheel and put them in my generation too and haven't looked back My generation 2 is actually get better gas mileage than the two generation threes that I had or right at the same It's really a tricky one to fix not because there's anything special to do there's nothing special to this any Toyota mechanic can work on this engine this is the same as a Corolla It just has different camshafts and they allow the engine to regurgitate its own junk probably kind of Why it craps itself out I guess I don't know. Me personally I wouldn't do anything about it I'd find me a generation two at a tow lot that I could get for about $700 go over there with a 12 volt or your jump pack they're all around you I'm sure well not unless you're in the rust belt maybe not but everywhere else these cars are plentiful and they're coming off the road and droves for whatever people's reasons they're not blown up they're just old they don't keep up with the Joneses all of those personal people reasons I just put a hybrid battery in and now the brake actuator went hands go up I'm out I'll take the Chevy Aveo thank you I buy mine like this and you can too or you don't.
  3. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    You haven't cleaned your EGR and you've driven 271,000 miles?
    Didn't you know that a dirty EGR will cause rough running, overheating, coolant leaks, and ultimately an engine rebuild?
  4. Jdh2425
    Baltimore
    To Tom, yeah mine has the JBL and solar roof, too! To Max, yes, that is correct (I bought it used with 86k miles 7 years ago). Everyone said it would burn oil and mine never has, even to this day, and mine has run perfectly through all kinds of use, so I figured I just got a good one, or it was an issue that affected more cars than normal, but not every one. Obviously I was mistaken.
  5. Mendel Leisk
    40,457
    Something is not adding up here. How long have you had this car? Any chance it’s already had an engine replacement, or a rebuild with pistons/rings or short block replaced?
    or the odometer’s been rolled forward lol.
    addendum: see your post above with more info, still an amazing puzzler.
  6. Jdh2425
    Baltimore
    Mendel, yes, everything is exactly as I described. I had read the threads on here for a few years and and was always worried about the oil burning problem. I checked my oil constantly and always changed it when the light came on. Even now, it's exactly at the full mark, just as when I had changed it. I also always looked at my coolant tank and it was always in exactly the same spot. Since I seemed to have no problems, I figured my car missed being affected by those problems somehow. I bought the car used with 87k miles some years ago, and with it came some oil change and tire replacement receipts, but no other major work. I've driven it the rest of those 271k miles and never did any intake or EGR work on it at all. It always drove perfectly fine like the day I got it. I was hesitant about putting a new battery in it a few months ago, but I figured if nothing has gone wrong by now, it probably wouldn't. Haha on me, I was sure wrong about that!
  7. bbrages
    bbrages Member
    162
    47
    St. Louis
    I think it's worth fixing if you want to keep driving it. I don't know any local mechanics for you, though.
    I have a 2010 with 247k miles (and climbing). It also is not an oil burner. Will the head gasket blow before my teenaged son wrecks it? Stay tuned!
  8. Jdh2425
    Baltimore
    b
    Thanks for your suggestion. My initial thought was to get it fixed, too. I walked in to my mechanic and told him my situation, and he talked me out of dumping 4k, possibly more, into a car that old and with that many miles. He's probably right. It's just hard for me to try to get something new after just putting a 2k battery in it (plus all the other stuff that has more or less recently been done like brakes, sway bar, small battery, shocks & struts, and the lift & tires).
    I don't know, I'm torn over this. Obviously, if I get get him or someone else to replace the head gasket, I'd have them clean the intake and EGR system, and add a catch can. That would send his price over 4k. That's pretty steep. I was hoping there were members here who know of an "enthusiast" prius mechanic who is familiar with the job and knows all the Prius-specific EGR/intake issues, and also could do it for less hours (mine estimated 10 or 12 hours, I think).
    And BTW, I don't know your situation or history, but in case you haven't already, please take your car the get the whole EGR system and intake cleaned! (or do it yourself if you can). Everyone recommends adding an oil catch can, also. Take it from my experience, it can be running fine until one day it starts shaking, then it's too late! I wish I had taken the advice of the members here...
  9. LexCT200H
    LexCT200H New Member
    Houston
    Hi @Mendel Leisk : I attempted replacing head gasket on my 2013 Lexus CT200h (157000 miles). At this point, I just need to reassemble everything back, but noticed something on Cylinder 4 piston and block. Not sure what is the right thing to do now. Could you please look at pics of #4 and give me some suggestions? I have already resurfaced head, cleaned EGR, manifold etc, and was about to replace head gasket and reassemble everything back. What should I do? I’d greatly appreciate your opinion on this. Thanks so much!
  10. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Melted piston. Caused by high chamber temperature and long-term operation on a lean mixture.
    This is rare and you got a ticket.
  11. Mendel Leisk
    40,457
    Time for new short block?
  12. bbrages
    bbrages Member
    162
    47
    St. Louis
    I disagree... I think this damage was caused by a foreign object in the combustion chamber. You'll notice all the damage is in the "squish band" where the clearance is the tightest - except for the circular damage on the piston that looks like it matches the curve of one of the valves.
  13. bbrages
    bbrages Member
    162
    47
    St. Louis
    I don't think you want to reuse that head. Long block at least. Salvage engine would be my choice
