Head gasket repair.. what else should i do while its out
Discussion in 'Gen 3 Prius Main Forum' started by ms.chevious, Mar 30, 2020.
  1. ms.chevious
    ms.chevious Junior Member
    Friends,
    Im going to work with a mechanic to replace the hg. Looking for your recommendations on what else I should do while its out. 2010 165,000 miles.
    On the list
    Egr cleaning
    Intake manifold cleaning
    should i change the water pump?
    already done 1.5 yrs ago
    pcv - replaced at 135,000
    Spark plus - same time as pcv
    thanks much
  2. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    Water pump is good idea in my opinion, thermostat while your there. Some people
    Say don’t fix what ain’t broke, but when the water pump goes it could be game over very quickly before you realize what happened.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,332
    CA
    Definitely replace the Spark plugs. The coolant ingestion will foul the spark plugs.
    Otherwise, water pump and thermostat.
    Raytheeagle likes this.
