head gasket sealer in a bottle
Discussion in 'Gen 2 Prius Main Forum' started by oil_burner, Dec 12, 2018.
  1. oil_burner
    oil_burner Active Member
    249
    126
    Hi all, my Prius has 270k miles. It has been burning oil at a steady clip for the past 80k and it has recently started to smell of coolant in the exhaust with white smoke during the first few seconds of start up.
    With an engine this old I really have nothing to lose, it is the dead of winter and I do not want to do an engine swap until the spring. Should I try a bottle of head gasket sealer like the bars stuff? Has anyone tried this stuff and had positive results? My thinking is if I can squeeze another 5000 miles or so out of the car then I can do the engine swap when its warmer out.
  2. audiodave
    audiodave Active Member
    787
    268
    US
    I've used it on my old S10 to help with a radiator leak. It works but definitely makes a mess. Coolant looks muddy.
  3. kens97uber171
    kens97uber171 Active Member
    177
    132
    US
    There are some other special head gasket sealant products. All are a bit pricey $50 or so. Was called Steel Seal.
    If your going to swap the engine anyway you have little to lose.
    One other thing you might try, is to tighten the head bolts 1/4 or 1/2 turn. Maybe the extra clamping force will seal it up.
    SFO and Robert Holt like this.
  4. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    I have heard many people swear by a product called Liquid Glass for this purpose—-the active ingredient is Sodium Silicate. You’ve got nothing to lose, go for it.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    @Joele3 i believe used KSeal woth good results:).
    Think he has over 15k miles since the addition(y).
    vegan likes this.
  6. Kenny94945
    Kenny94945 Active Member
    780
    397
    Sausalito
    2016 Prius v wagon
    Well, if you are going to change the engine ...I guess there is little risk.
    FWIW I wouldn't use it if I was keeping the car because what ever this product is it will
    also get into the valve seats, spark plugs, exhaust system, oil system and perhaps
    even into the coolant system if there is a leak in addition to its purpose of sealing a
    gap between the top of the cylinder and the head.
    Decades ago I used Bars Leak for a radiator leak and it damaged the water pump
    bearings necessitating replacement. Thermostat and coolant passages issues are
    more than likely an issue too with these type of radiator leak additives. Yes it
    worked to plug the leak...as an on the road emergency product IMO
  7. Mendel Leisk
    38,634
    Every fiber in my body says don't do it!
    Meh, go for it.
    Skibob and Raytheeagle like this.
  8. audiodave
    787
    268
    US
    What happened to the pump? Start leaking? Lot of miles on it? It definitely makes a mess of the cooling system.
  9. Kenny94945
    780
    397
    Sausalito
    2016 Prius v wagon
    Hi Audio,
    Was a long time ago...Chevy 283, chrome valve covers :) , glass packs and all....maybe year 1969?
    My recollection is not so clear other than having to replace the pump after
    the Bars Leak application.
    Just don't recall if the pump bearing seized, was a noise or a leak?
    I do seem to recall the failure was fairly quick (weeks) after the application.
    I can't even recall if the rad leak started at a tank seam or a rock penetration
    to a tube.
    Also don't clearly recall what the coolant looked like after using Bars,
    so I would just be guessing as to grit and color....yet that's my guess grit & color
    were not good.
    Therefore, my trend to never recommend that Bar's additive.
    It was my take at the time the failure was due to this product...not pump age.
    At the time, I recall the Bars was in a film canister sized container and was a silver
    colored flake.
    I am not sure of the product's current evolution.
    So long ago, so many cars ago Audio.
    I would say to use Bars as a true emergency road repair.
  10. Mendel Leisk
    38,634
    Somewhat comparable to using stop-leak in a tire? Fine, as long you're planning to throw away the tire, and the rim...
  11. El Dobro
    El Dobro A Member
    6,978
    3,213
  12. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    And the radiator, and the heater core. That stuff typically clogs everything
