1. curthens4
    curthens4 Junior Member
    US
    2015 Prius c
    Well, took the 2012 to the Toyota specialist this morning to have it diagnosed. I'm thinking it's the head gasket, but crossing my fingers. Started shaking at start up a little, and losing a bit of antifreeze.
    She has 184,000 on the clock. We will see when I get a call.
    Pixel 5 ?
  2. Mendel Leisk
    41,963
    Was the EGR ever cleaned?
  3. ASRDogman
    ASRDogman Senior Member
    7,858
    4,003
    The Prius "C" is different than the regular Prius.
    I am not sure if it has the same egr problems....
  4. Mendel Leisk
    41,963
    OP’s avatar says they have a ‘15 Prius c, but talking about a ‘12, and it’s third gen forum, so not c? Should clarify.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    If it's a c, I've cleaned quite a few. They never seem to be very dirty. But I'm sure it can happen.
    Either way, loosing coolant combined with engine shake on startup isn't a good sign.
    Hoping it's an external leak and maybe a failing ignition coil, but I'd expect the coil to make it keep shaking.
    Any codes?
    ASRDogman likes this.
  6. curthens4
    US
    2015 Prius c
    Sorry, no, it's not our Prius C. That is a 2015. It is our 2012 Prius. 1.8L.
    I'm not sure that it has been. We purchased it used.
    No, not our C. 2012 with a 1.8L.
    No codes at all.
    #6 curthens4, Feb 13, 2023
  7. bisco
    52,434
    if worst comes to worst, there's a traveling mech here who can replace your engine
  8. Hoolia
    Hoolia New Member
    Seattle
    Does anyone have experience with Gasket Masters in CA? I am looking for an engine replacement for my 2012 V @ 185K..
  9. bisco
    52,434
    good and bad, you can search here
