Head light bulb R&R on a Gen 3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ETP, Mar 8, 2014.
  1. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Just curious how to do this as I saw my first gen 3 on the road with the left head light out.
    Post links please.
    Thanks all,
  2. JGC61
    JGC61 Active Member
    214
    101
    Long Island
    Left side is an easy fix. The right is difficult.
  3. ptn
    ptn Junior Member
    24
    Orange County, CA
    Headlight Change 2010-2013 Toyota Prius - 2010 Toyota Prius 1.8L 4 Cyl.
    As for passenger side, you don't necessarily have to unbolt the air intake. I could reach that bulb but I have small hands and I knew where the bulb was located.
    Make sure you are aligning the tabs correctly when putting the bulb back. One of the tabs are bigger than the others and should firmly lock into place if you put it in correctly. You turn the bulb counter clockwise to take the bulb out so make a note of that when putting the bulb back.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    +1 on the passenger side being a PITA to reach.
    SCH-I535
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    I'll upload a video of it soon. :D
    Princer and Mendel Leisk like this.
  6. NutzAboutBolts
    1,476
    1,552
    Bay Area
    Here's the video, I hope it'll help someone.
    Princer, Robert Holt and ptn like this.
  7. ETP
    2,801
    1,170
    Auburdale FL
    Thanks all,
  8. NutzAboutBolts
    1,476
    1,552
    Bay Area
    No problem, hope you got it changed.
  9. NutzAboutBolts
    1,476
    1,552
    Bay Area
  10. slimothy
    slimothy Junior Member
    Seattle, WA
    I found that the bulb on my gen3 is not seated properly (low light output and light leak into the engine compartment). Since I don't know how it was exactly seated the last time, does the bulb go in at the 9 o'clock position (if looking from the back of the car) and then turn it to the 6 o'clock position?
    Alternatively, does the bulb go in exactly like on the driver's side, or is it mirror imaged?
  11. xliderider
    7,869
    3,116
    Honolulu, HI
    I believe it goes in at the 3 o'clock position and turns to the 6 o'clock position to lock in on both sides if looking from the back.
    SCH-I535
  12. slimothy
    Seattle, WA
    Thanks. That did the trick. I was unsuccessfully trying to work it in from the 9 o'clock position; doing it the other way was pretty straightforward once I got the angle right. They sure don't put a lot of slack in that cable.
    I found that putting a shop towel by the intake and other sharp bits reduced the scrapes on my arm considerably.
  13. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    So, I read all the posts, looking for best low beam Bulbs for 2011 Prius; SilverStar Ultra?
  14. xliderider
    7,869
    3,116
    Honolulu, HI
    H9 bulbs modified to fit in H11 mount. Link to information in my signature below. Watch the excellent video posted by mediahound at the end of the thread.
    Premium H11 bulbs are way overpriced. Quality H9 bulbs like Osram and Philips are about $20 a pair and put out 50% more light than H11 bulbs.
    Sergiospl likes this.
