Head Unit vs Standard Unit Photos
Discussion in 'Prius c Accessories and Modifications' started by ROLOPR, Jan 18, 2013.
  1. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Can someone provide photos of the back of both the Head unit and the Standard radio, I want to see any differences in terms of plug connectors. If explanation of what is connected to better.
    The reason for this thread is that I get a deal to buy a Head Unit, GPS antenna and steering wheel from a PC4 to incorporate in a PC2.
    If I see is too much complicated go to Aftermarket.
    Finally what is that box under the Head Unit for in the following diagram?
  2. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Ok what do I need in order to use the Head Unit on my Prius C 2 other than the GPS antenna and the voice command botton on the steering wheel?
  3. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    I found it, now can someone tell me what are the connectors for???
    I know # 5, 6, 7, 8 & 10 are in the Standard Radio.
    But I want to know what are each one do for better undestanding before I go with Aftermarket Head Unit.
    Please thanks.
    PriusC_Commuter likes this.
  4. walay
    walay Junior Member
    2013 Prius v wagon
    I would like to know as well, where is the radio antenna plugged into?
  5. KYBlue
    KYBlue Active Member
    227
    112
    Antenna is #8. The box below is the sat radio unit. It is linked from that box to radio via 11 and or 3.
  6. KYBlue
    227
    112
    BTW if it was me, I'd go aftermarket, in fact, I am.... The entune isn't worth the hassle/limitations to make it force fit in a PC2.
  7. wmo168
    wmo168 Member
    239
    49
    South Florida
    Is doable, I got the Nav p3 unit working in my p2 after try to figure out everything goes... GPS Antenna can put on top of the center vent hidden.
