Headlamp - need to replace burned socket ! can't locate part
Discussion in 'Prius v Technical Discussion' started by pun84, Apr 12, 2022.
  1. pun84
    pun84 New Member
    Hello,
    I have a burnt socket, it is essentially a piece of plastic that is removable with three screws. I have been on the Toyota parts site however I can't seem to find the part I need.
    I have attached a screenshot of the bulb retainer/socket - I am really hoping someone here has been able to locate this part
    Thanks,
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    Check with the Toyota dealer in their parts department. My guess is you need a new headlight assembly or need to get one from a salvage yard.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    You need a new or used headlight assembly. There is no replacement part, it's glued or ultrasonically welded on.
